Old 10-02-2006, 06:41 AM   #1
my350tpi is on a distinguished road
Only one fuel injector, um, injecting.
Hi all! I've got a 1992 silverado 2wd with a 305 tbi in it and only one of the two injectors are working. It'a an electrical problem as switching the leads to the injectors will move the problem from one side to the other. On the blue wire (passenger side injector), I have no ground. Does anyone know where the ground comes from for this lead? Thanks!!!!
P.
my350tpi is offline   Reply With Quote
Old 10-02-2006, 08:52 AM   #2
I am not certain but usually the computer controls the ground circuit. If you get a good wiring diagram you should be able to trace it. Even if the wire goes straight to your computer it does not mean your computer is bad it just may be one of the grounds to the computer. Some cars have 4 grounds to ecm.
Old 10-02-2006, 06:26 PM   #3
this should help. the pink wire goes to a mini-fuse under the hood labeld ecm-1.
i'd rather be hunting
Old 10-03-2006, 06:31 AM   #4
You can see the wire for both injectors goes up that usually indicates Vcc ( 12v.) Next I would look to find which wires for the ecm go to ground and clean with sandpaper and install toothed electrical washer if it doesn't already have them. Still not absolutely certain but it does look like ecm is controling the ground to the injectors. You can also check the voltage at each of the two wires connected to the ecm while they are connected and car is running. If it is acting as a ground voltage should be quite low (.2v )or so on digital volt meter. If you read higher then you have a poor ground if you read 12v you have no ground, or I have it *** backwards and the ecm is supplying 12. Measure the injector line that is working first that should tell you how it works. Good luck let us know what you find. Do not use analog (needle) voltmeter.
Old 10-03-2006, 07:11 AM   #5
forgot to add the pink wire is constant hot.
1987 throttle body fuel pump problem wojeepster Chevy Truck Forum 11 10-28-2009 02:53 PM
fuel level gauge 396chevy Chevy Truck Forum 1 08-12-2006 08:02 PM
Contaminated fuel system Phil R Chevy Truck Forum 2 07-23-2006 01:00 PM
Fuel Pump will not turn on? cab41610 Chevy Truck Forum 7 07-17-2006 08:33 PM
fuel problem braggent Chevy Truck Forum 0 07-14-2006 01:16 PM
