Old 10-12-2006, 05:52 AM   #1
02S10X is on a distinguished road
Heating Problem
Bought an 02 xtreme 4.3L. It had heat when I got it and now the heat is getting colder. Coolant level is ok and I changed the thermostat. Defrost mostly is blowing cooler than other vents, when the control panel is turned off it seems to blow hotter down at the foot vent. My question is could this be a clogged heater core or the hot cold switch on the control panel?
02S10X is offline   Reply With Quote
Old 10-12-2006, 10:50 AM   #2
Moderator
could be several things. i dont think that you would have a clogged core but anything is possible. you do have a valve that opens and closes the hot water entering the heater core that is malfunctioning. i have had that problem before. you might also have a problem with the control panel like a fuse or something actually in the panel.
Old 10-12-2006, 01:17 PM   #3
bobcat5544's Avatar
bobcat5544 is on a distinguished road
With the truck running and heater/ac on will air blow out of the vent you select (defrost, dash vents, floor). With the controler on cold select vents. move the knob from cold to heat does any heat come out, when doing this listen on the passanger side under the dash do you hear a constant vacuum sound.
bobcat5544 is offline   Reply With Quote
Old 10-13-2006, 05:51 AM   #4
I talked to a guy at a GM dealer yesterday, he told me they have seen this problem before. He said to back flush the heater core, the dexcool antifreeze for some reason gets gummed up in the heater core. Of all the trucks they have done this on he said it has worked. I will try it this weekend and let you know.
2005 4WD Vibration Problem not_a_mechanic Chevy Truck Forum 6 10-11-2006 07:08 PM
'99 F250 SD with strange problem ColoQuarterH Ford Truck Forum 4 08-20-2006 10:37 AM
Hello All\help..94 Diesel Stalling Problem collision guy Introductions 3 08-01-2006 07:16 AM
1997 chevy tahoe gage light problem bajaboy Chevy Truck Forum 5 03-23-2006 08:58 AM
Abs Problem??? MARK326 GMC Truck Forum 1 12-30-2005 01:01 AM
