| Senior Member Join Date: Sep 2006 Location: Ipswich,Massachusetts Home of the Clam
| My problem continues... History >>My 1998 S10 V6 , always ran great .. filled up gas tank, drove home parked in driveway, went away vacation for a week.... Truck sat for a week...came home Started truck engine rough ,drove short distance , seemed like not getting enough gas...........installed new fuel filter & flushed line, fuel pump has plenty of volume ...........ran great 2 days >> , no start resurfaces after sitting at night .so I check fuel pump via disconeecting filter.. seems ok, reassemble runs great all day...next mourning no start... I replace new filter , again ...runs great all day( many starts), EEK ,wont start next mourning.... I clean out throttle body & replace vac line to fuel pressure reg ..tighten various bolts ,check electrical contacts & disconnect fuel filter again ( 3rd time ) fuel pums sees ok...Starts instantly runs great 2 days ..drive 50 miles ..75 MPH smooth......yesterday no start again >>>> BUT if I dpresse pedal to floor while cranking ,,started but runs a little rough & but smoothed out,after a little driving, now after sitting overnight wont start even with pedal to floor...tied the reconnect & dicconect fuel line still wont start... check engine light on so i have a code.guess ill need to borrow a scanner.......
__________________ Semper Fi Last edited by STRAYDOG; 10-18-2006 at 01:41 PM. |
| Its an OBD2 scanner. If you had the book it shows how to jumper pins and get the check engine light to flash a certain number of times to diagnose it without a scanner.
| i didn't think you could jumper the pins on the newer vehicals like you could on the '95? and older.
| Think I willl stop screwing around & have AAA tow her to a mechanic, funny I rebuilt the engine in my 66 Corvette with out problems , can rebuild carburators & transmisions but cant figure out how to diagnose & repair my 98 S10. The fuel pump is filling a container in a few seconds so the fuel situation is down stream or upstream maybe its a sensor .....she just spins/cranks ,now wont even even try to start now no matter what I do ....dam wish I could diagnos my problem. woe
__________________ Semper Fi |
| find out what codes it shows and we might be able to point you to a direction. |
| Senior Member Join Date: Nov 2005
| Try this book. Best book I have ever found on this subject: http://www.amazon.com/o/ASIN/0760320...430199-6319828 |
| Full Member Join Date: Oct 2006 Location: south carolina
| Sounds to me like your fuel injectors are leaking down when engine is sitting for extended periods.In turn ,when you try to start the engine,it is flooded.Thus the initial rough start ,then the smoothing out as the air/fuel mixture meters properly.When you push the accellerator during the start,you are not giving the engine more gas because it has electronic injection.But you ARE allowing more air through the throttle body,which helps to stabilize the fuel mixture enough for combustion to take place.There are tests to be performed to pinpoint this problem,however,if you are not an experiencd mechanic,it would be best to take it to a reputable service station.I hope this has enlightened you and put you on the right track. 92gmc4x4 |
| Oh by the way,you cannot get codes from an obd2 computer w/ a jumper wire.The pulsing service light method was on obd1 certified vehicles. |
| | #9 | |
__________________ Semper Fi | |
| there are differant typesof scanners. just because one scanner doesnt show anything doesnt mean there might not be anything wrong. on most items underneath the hood, the computer will detect that there is something wrong before it throws a code. it will try and correct it first. there are code readers out there that will pickup on these and actual codes that are active. i would like to know what codes are pending. you understand?? |
