Old 10-20-2006, 11:24 AM   #1
crazyhorse357's Avatar
crazyhorse357 is on a distinguished road
replacing axle bearing
Greetings Everyone,
I have noticed that the right rear on my 93 G-20 van sounds like I have a mudgrip back there, I have been told that it is an axle bearing going out, my question is do I have to take the cover off the rear end to get the axle out in order to replace that bearing, or is it a floating axle and all that is required is to pull off the brake drum, shoes, and backing plate.
I checked the grease in the rear end and it is full, so that's not the problem.
all information will be greatly appreciated,
Frank aka crazyhorse357
1996 Lincoln Continental
1993 Chevy G-20 conversion van
crazyhorse357 is offline   Reply With Quote
Old 10-20-2006, 11:48 AM   #2
chevyguy's Avatar
Depends on which bearing are going out. Cound be the carrier bearings, or the axle bearings. Either way the axles have to comeout and if its the wheel bearings, then the hubs have to come off.
Old 10-20-2006, 02:33 PM   #3
reply
Well there you go,
I didn't even know there were two sets of bearings,
how an I supposed to tell which ones are bad, I have repacked and replaced front wheel bearings, but never had an opportunity to work on the rear before.
Thanks for your swift response Chevyguy,
Old 10-20-2006, 06:56 PM   #4
chevyguy's Avatar
remove the rear cover. It should help, Have a look inside.
Old 10-21-2006, 11:10 AM   #5
Thumbs up reply
Thanks chevyguy,
It does seem like the logical place to start, I will do as you suggested and if you want I will keep you informed as to what I find.
many thanks,
Frank
Replacing the Clutch John_and_Donna Chevy Truck Forum 2 08-20-2006 03:45 PM
axle shaft seal on 4x4 ramdodge Dodge Truck Forum 1 12-03-2005 03:25 PM
gm 10 bolt rear axle RingtownJoe Chevy Truck Forum 0 10-15-2005 03:44 PM
American Axle & Manufacturing Announces Launch of ****** H3 Program (The Auto Channel) trucknews Truck News (headlines) 0 04-29-2005 11:30 AM
Truck Axle From OKC Bombing Gets New Home Axle, Other Items Go On Display At Museum (40/29 KHBS/KHOG) trucknews Truck News (headlines) 0 04-10-2005 05:30 PM
