Old 10-30-2006, 07:09 PM   #1
tdolbow is on a distinguished road
Exclamation help! no rear lights on suburban!!
please help, military husband away and i only have the one vehicle. out of the blue, i have no tail lights, brake lights, no reverse lights, and no light over license plate, all front lights and interior lights work. have checked all fuses inside the truck and under the hood, all good. i even checked the light control on dash to make sure everything is hooked up. i have to drive this vehicle to take kids to school and go to work. please help soon, dont know what else to check!
tdolbow is offline   Reply With Quote
Old 10-30-2006, 07:19 PM   #2
chevyguy's Avatar
Let me guess, its 1995 or newer? I am willing to bet its the control in the steering column. I have changed out several for this very reason. Check under the truck on the wiring harness and make sure it didnt get damaged somehow, But I think its time to get it to the shop because the airbag has to be removesd to get the steering wheel off.
Old 10-30-2006, 08:24 PM   #3
um? I hope not!!
Let me guess, its 1995 or newer? I am willing to bet its the control in the steering column. I have changed out several for this very reason. Check under the truck on the wiring harness and make sure it didnt get damaged somehow, But I think its time to get it to the shop because the airbag has to be removesd to get the steering wheel off.Today 08:09 PM
okay let me be a little more specific in the hopes that you are not right on this one, its a 1999 suburban 1500 (i should have said that earlier). i have had nothing but trouble with this stupid truck since i bought it, we just recently replaced both rear tail light assemblies, only about $80 a piece , it only been about 3 months, and now i have no power to them all of the sudden. if u have any more ideas please offer them, i dont want to have to take this thing to the dealer again, can't afford it right now!! thank you for your prompt reply though
Old 10-31-2006, 02:39 PM   #4
72'CaminoKid's Avatar
72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold
replied to your PM, i'll continue to respond in here, this is the first time i've been on here in a couple days, so i never saw your post until after i go your msg.....
99 suburban xlt
96 silverado
91 wrangler (my baby )
Old 10-31-2006, 05:06 PM   #5
There is a junction block for the rear lights mounted right rear behind right wheel and has like 3 connections it is a square flat box and lots of times they get water in them that is where i would start to look or with the lights on wiggle and have someone look to see if any of the rear lights flicker or come on.
Old 11-01-2006, 09:10 AM   #6
thank you, thank you!!!
thank you very much for your replyl, i went out to the truck this morning and sure enough i reached under the bumper and there it was disconnected, as soon as i plugged it back in to each other they came right on. thank you so much, i am forever grateful. tina
Old 11-01-2006, 06:35 PM   #7
chevyguy's Avatar
Good call GM tech. I missed that one.
Old 11-02-2006, 02:38 PM   #8
no problem tina, and since the rest of yall didnt see what i said bc it was in a PM, in case you ever encounter a similar problem...... the trailer light connector can get ripped off while driving off road and when this happens you lose your rear lighting bc the way the trailer light connector is "spliced".... i dont really know how to explain it, but GMtech, i'm sure you know what i'm talkin bout, and CG, just take a look under the back bumper next time your around a 99 burb
99 suburban xlt
96 silverado
Old 11-02-2006, 11:57 PM   #9
chevyguy's Avatar
i know what your talking about. Good call.
Old 11-03-2006, 02:50 PM   #10
i only knew bc it happened to mine a little over a yr ago....
99 suburban xlt
96 silverado
76 Chevy 454 - massive oil leak in rear of engine MrDavidOgle Chevy Truck Forum 19 10-07-2007 01:46 PM
89 chevy suburban rear main oil seal The Bondo King! Chevy Truck Forum 3 09-21-2006 06:45 PM
1994 Ford F-250 Rear Diff. fluid Dave8792 Ford Truck Forum 4 09-12-2006 04:24 PM
rear end turbosean Mazda Truck Forum 0 07-11-2006 03:02 AM
Track width for 1987 Suburban DarthD Chevy Truck Forum 0 02-11-2005 05:46 AM
