Old 11-14-2006, 04:42 PM   #1
Hayden's Avatar
94 Blazer 4.3
94 Blazer 4.3. I get a code 32 which is egr. My Question. Will a bad egr cause the engine to Idle bad and stall. any help is greatly appreciated on this matter. Autozone says there are two types of egr for this vehicle. 1 costs $119.00 and the other $205.00 I'm not sure which it is till I get it out.
Old 11-14-2006, 05:23 PM   #2
jay996's Avatar
jay996 is on a distinguished road
First try and clean the egr valve and the mounting point of the intake manifold,it is a very common problem for the valve and mount point
to get plugged up with carbon.It is a very easy thing to check,I believe it is two 9/16 bolts,don't hold me to that!!!Its been a while! Check the valve for carbon deposits.
jay996 is offline   Reply With Quote
Old 11-14-2006, 05:32 PM   #3
yes the egr valve will make the engine act like that. that price is very high. gm didn't cange body styles till 95 which i think is when they went to the vortec engine, so unless you some how have a vortec engine then the egr valve should only cost around 50 dollars. i know because i had a 89 4.3. i would snap a pic and take it with you, more than likely the autozoner hit a 5 instead of 4 in the year. if they happen to be right i would try cleaning it and saving me a hundred bucks. good luck.
i'd rather be hunting
Old 11-14-2006, 05:39 PM   #4
The diference is the 8th digit in your vin number if it is a z it has a vacuum egr valve which is cheaper and if you have a w it is an electronic egr more expensive and those styles get carbon debis stuck in them pretty comon can be cleaned out and reinstalled its mounted right below the throttlebody.
Old 11-14-2006, 07:38 PM   #5
gmtech, is that true on most year models?? ive never known that
Old 11-14-2006, 07:43 PM   #6
Yeh they started using the electronic egr valves in 94/95 on up and they have very little spring tension to close them so carbon gets stuck in them causing a vacuum leak so you get a rough idle and hard brake pedal mostly in the 4.3 w engines
Looking for parts for my 72 Blazer OldChevyGal Truck Classifieds 1 07-19-2006 03:40 PM
1994 S-10 Blazer will4831 Truck Classifieds 0 05-02-2006 09:04 PM
Blazer Transmission mikerike Chevy Truck Forum 8 11-19-2005 10:50 PM
QCTimes.Com: Top Jobs: CHEVY '93 S10 Blazer Tahoe 4x4 4 Dr. (Quad-City Times) trucknews Truck News (headlines) 0 08-31-2005 03:30 AM
QCTimes.Com: Top Jobs: Chevy '00 Blazer 4x4 (Quad-City Times) trucknews Truck News (headlines) 0 06-02-2005 03:30 AM
