| Full Member Join Date: Sep 2006
| 91 4x4 I would like to replace the shocks on my 91 4x4, because they have never been replaced, and the truck has a harsh ride. ca anyone recomend a decent shock for my truck? i use it in the sand sometimes, and am planning on some sligtly larger than stock tires as well. would replacing the front shocks level the truck out at all? |
| Junior Member Join Date: Nov 2006
| If it is still stock, then the front end is approx. 2 inches lower by design, so the shocks won't level it. If you are going to lift to accomodate larger tires, then buy a leveling kit when you do. |
| | #3 | |
__________________ John Wayne 2000 F-350 7.3L Powerstroke 4x4 | |
| Thanks for the advice. i thinl i will go with a level kit and small lift |
| A 4" lift would accomodate 33" tires nicely without gearing concerns. A 6" lift would do good with 35" - 37" tires but there's a concern with gearings. If you'er going with a small lift (4") you don't need the leveling kit, it'll level out. Hope this helps.
__________________ '85 Oldsmobile 442 '93 Chevy 2WD C1500 350 Silverado Extended Cab Shortbed '95 Chevy 4WD K2500 454 Silverado Extended Cab Long Bed |
| how wide could i go with the tires on a 4" lift? |
