Old 11-22-2006, 04:00 PM   #1
GENE is on a distinguished road
Question Chokin Smokin
HI,I have a 1990 C-1500 w/5.7 that is driving me crazy. It has TBI.It will start up fine then the trouble begins.Once it warms up it still blows out black smoke like the choke is stuck on even though it has TBI.If I drive it down the road it dies out.I have replaced fuel pump.Somebody says map sensor,tbi itself.Can somebody please help me?
GENE is offline   Reply With Quote
Old 11-24-2006, 09:23 AM   #2
Chevy808's Avatar
Black exhaust is an indication of a rich mixture or burning of oil. Pull the codes off of your truck and see what it gives you. If I could take a wild guess without the codes I would say your MAP sensor or plugged catalytic. Um....don't want to say bad rings.
'85 Oldsmobile 442
Old 10-09-2007, 12:03 PM   #3
lb23 is on a distinguished road
Black smoke = fuel
Blue smoke= Oil
White smoke = coolant
lb23 is offline   Reply With Quote
Old 10-09-2007, 01:28 PM   #4
tjzz4 is a splendid one to beholdtjzz4 is a splendid one to beholdtjzz4 is a splendid one to beholdtjzz4 is a splendid one to beholdtjzz4 is a splendid one to beholdtjzz4 is a splendid one to beholdtjzz4 is a splendid one to behold
Pull Codes First For Sure But I Have Also Seen An Ect (engine Coolant Temp) Sensor Do That.. If The Ecm Thinks The Engine Is Cold It Will Dump More Fuel.
Old 10-09-2007, 01:45 PM   #5
Moostang's Avatar
The OP hasn't been on since March (posted question last year), I hope he has gotten it fixed.
MEOW!!
Old 10-10-2007, 05:15 PM   #6
chevyguy's Avatar
Temp sensor all the way.
Old 10-10-2007, 06:38 PM   #7
pbouffard's Avatar
pbouffard is on a distinguished road
coolant temp sensor fist cheap part like 11.99 also ecm can send the pulse wire too much resistance and cause too much fuel to dump, but temp sensor first
IF YOU CANT FIX IT....IT MUST BE MADE IN TAIWAN
pbouffard is offline   Reply With Quote
Old 10-11-2007, 03:24 PM   #8
chevyguy's Avatar
It runs great till it warls up. THe program is set to default for a short time to allow the motor to warm up. After that the temp sensor is the reference to tell the computer what the temp is and it defaults to -40 degrees if the temp sensor is bad.
Old 10-14-2007, 08:18 AM   #9
strokin350's Avatar
strokin350 is on a distinguished road
it's deffinatly the CTS i just went though the exact same thing on my 92.
strokin350 is offline   Reply With Quote
Old 11-01-2007, 09:34 AM   #10
ryeja is on a distinguished road
Just out of curiosity, does anyone know what the ohm values should be for the CTS? I'm experiencing similar problems but would like to diagnose further. I'm reading 0.3 omhs when cold and around 0.5 ohms after about a 20 min warm up. I;m not getting any trouble codes until I unplug the sensor.
ryeja is offline   Reply With Quote
Smokin Chevy Itstali25 Chevy Truck Forum 18 01-10-2006 09:01 PM
Smokin' Wheels wraps up (Pacific Daily News) trucknews Truck News (headlines) 0 04-17-2005 11:30 AM
