| Full Member Join Date: Nov 2006
| I have a 86 c20 need to rebuild the gas tank mount wanted to get used no one has 1 every thing rusts out up here in NY last owner used band iron and strapped it to running board (now that is a good plan lol the tank mount or what is left of it turns under tank and rotted off just after turn under tank any pix of what it is supposed to look like whole If I can get a good look at one just may try to build new 1 myself any input would be great Don |
| look at the diagrams that lmc truck lists in their books. if not there, let me know. will take a pic of the one i got at the house. |
| ok will look again I will look again looked the other day and only found tank straps maybe not looking hard enough Don |
| Junior Member Join Date: Jan 2010
| I know this is an old thread, but i am having the same sort of problem. I am fixing up an 86 silverado c20 with dual tanks.... all the tank mounts are rusted up. Both of the tanks that were on it leak really bad... need to change them out. They are 20 gal tanks. I have two new 16 gal tanks Here is the problem... not sure if the 16 gal tanks will work with the way the holes are drilled on the frame presently? Do I really need to go out and get the 20 gallon tanks? Or is there a way to do all this that i am not thinking of that will work? Do i have to go out and get, or make, the mounting brackets? or is it possible to just mount the tanks using just tank straps....????? Any help would be really appreciated Thanks Sam |
| Full Member Join Date: Jan 2010 Location: Iowa
| You can use the 16 gal tanks, but you might have to move one of the mount brackets, and drill new holes for it. been a while since i put in a 16 gal, usually everyone wants the biggest tank they can fit in there. |
| thank you.. gonna try that... have to refurbish the old brackets first they are pretty rusted out .... OHIO sucks for rust |
| Just want to point out, this is why OLD THREADS, DO NOT need to be closed !!! Welcome to the forum Sammy. Good Luck with this. I have an 86 C20 with dual tanks. Not sure of the size, I know it cost a fortune to fill the truck, but if you need underside pics and can wait til a better weather day, I'll snap a few for you. Its just wet out right now, and not wanting to lay on the cold wet concrete. Monday may be a good day. Let me know.
| Offroad Cab Light Mount | sktw8 | 4x4 trucks / off road | 2 | 12-09-2006 05:34 PM |
| off-road light mount? | mudseeker | 4x4 trucks / off road | 5 | 08-23-2006 06:18 PM |
| Fuel Tank needed 93 HardBody 4x4 v-6 kingcab | XJBEAST96 | Truck Classifieds | 1 | 08-15-2006 11:43 PM |
| duel fuel tank problem | srw45 | Chevy Truck Forum | 0 | 12-11-2005 02:45 PM |
| Freightliner announces layoffs at Mount Holly truck plant (News 14 Carolina) | trucknews | Truck News (headlines) | 0 | 08-31-2005 08:30 AM |
