| Junior Member Join Date: Oct 2006 Location: Illinois
| chokes on power/1989 silverado the truck starts fine and idles,but going down the road it not get over 45 miles and hour. When you give it the gas it chikes up and seems there is no fuel. It will not gain any speed. |
| | #2 | |
__________________ '85 Oldsmobile 442 '93 Chevy 2WD C1500 350 Silverado Extended Cab Shortbed '95 Chevy 4WD K2500 454 Silverado Extended Cab Long Bed | |
| It will not accelerate when giving it more gas. Only get about 45 mph. That is on flat road and no hills. |
| Full Member Join Date: Nov 2006
| Its possible the fuel delivery system is fouled. Have any codes been thrown? |
| Well it could be a lot of things but I would start with the ignition then. Timing, distributor, plug/wires that sort a thing. Oh, a do a cat check too to see if its plugged.
| Junior Member Join Date: Dec 2006
| I had the exact same problem on two fuel injected vehicles. Would start and run fine, but would die on application of a lot of throttle, just like no fuel there...........well that was the problem. Changed fuel filter on each and problem gone. |
| That is what I was thinking fuel filter. Thanks I will try that. |
| Will It Do It If You Are Still And Just Give It Gas? Start With Changing The Fuel Filter And Check Fuel Pressure. It May Not Hurt To Clean The Injectors As Well. |
| 1989 Silverado S2500 Tranny only works after 15 minute warmup??? | michelschevy | Chevy Truck Forum | 8 | 12-13-2006 06:20 AM |
| 80 silverado (gearing) | talaka | Chevy Truck Forum | 10 | 11-22-2006 08:17 AM |
| 2002 Silverado Lift Kit | Kevin Hod | Chevy Truck Forum | 13 | 05-08-2006 12:01 AM |
| give me input on your 98 silverado | ndiddy641 | Chevy Truck Forum | 6 | 01-24-2006 05:46 PM |
| 2003 silverado | george405 | Chevy Truck Forum | 2 | 12-05-2005 11:01 AM |
