Old 12-08-2006, 11:32 AM   #1
elkfool is on a distinguished road
7.4L Hard Starting
I have a 99 Silverado with a 7.4L Vortec that was overhauled 3500 miles ago.
Ever since I have reinstalled the engine it has had a hard starting issue where when it is warmed up it turns over for 3-4 seconds before it fires right up.
When it is cold it ALWAYS fires right up but when it is warm it has this issue. Once it fires it fires right up and idles smooth. I have no fault codes or other noticable issues with the truck.
What should I look for to alleviate this issue? Have any of you had this issue with your trucks?
elkfool is offline   Reply With Quote
Old 12-08-2006, 02:03 PM   #2
2verpsters is on a distinguished road
I owned a 99 3/4 ton crew cab with the same motor and had the same problem. I never did figure it out and since I knew the boys at the local Chevy garage, we tried all kinds of stuff. Cold starts were awesome, hot starts were a 30 second ordeal where the motor turned and turned and then finally caught, but then coughed and sputtered for a few seconds before it returned to a smooth idle. Acted like a carbed motor, 1st like it was flooded, and then once it started, like the choke was stuck on. Tune ups, from air filter to plugs didn't help. Resetting the comp didn't help. New air flow sensor didn't help. After market parts made it worse. Only good thing I can say is that it always started eventually. I put 124000 miles on it and it never let me down, so I just put up with it.
2verpsters is offline   Reply With Quote
Old 12-09-2006, 12:40 PM   #3
Chevy808's Avatar
Sounds like a fuel pressure regulator problem. $60 -$70.00 replacement fix. A leaking injector can cause fuel pressure drop too so you might want to check that also.
'85 Oldsmobile 442
Old 12-11-2006, 07:51 AM   #4
Moderator
bradrhale has much to be proud ofbradrhale has much to be proud ofbradrhale has much to be proud ofbradrhale has much to be proud ofbradrhale has much to be proud ofbradrhale has much to be proud ofbradrhale has much to be proud ofbradrhale has much to be proud of
an injector leak is going to have tell-tale signs when you crank it up and it hits on that cylinder.
Old 12-11-2006, 10:01 AM   #5
We did the pressure regulator route, didn't change anything on mine. It is a cheap fix, but a pain in the butt to do. It's hidden underneath the funky intake plenum that Chevy put on those motors. You need to split the plenum to get to it and a set of new gaskets for the plenum, luckily you don't need to get into the intake at all. Injectors are a good point, I don't think we ever did anything with that on mine, but it doesn't seem like that motor had individual injectors on a rail, I think it was one big one that fed all 8 cylinders. I could be wrong on that though, it's been a while since I had that truck.
Old 12-12-2006, 01:05 PM   #6
Maybe a vacuum leak?
I had a (not so) similar encounter with my old truck and the breather element was not on tightly at the intake.
I sprayed starting fluid at vacuum connections (while the truck was running) and that is how I found the problem.
Old 12-31-2006, 10:02 AM   #7
I installed a GM fuel pressure regulator and so far that seems to have fixed the issue.
1987 Silverado 350 TBI Auto., hard start, won't idle 87Silverado Chevy Truck Forum 8 07-08-2007 07:20 PM
2000 Chevy tranny shifting hard tdbp76 Chevy Truck Forum 5 04-22-2007 09:48 PM
Hard starting, sluggish when cold. prowler40 GMC Truck Forum 2 11-06-2006 08:09 PM
96 GMC truck, hard shifting after a alternator failure ? WAHOO GMC Truck Forum 1 10-13-2006 10:03 PM
'98 Chevy starts hard will4831 Chevy Truck Forum 11 06-01-2006 12:20 PM
