| Junior Member Join Date: Dec 2006
| rough running This is my first using one of these forums. Here is my question. I have a 1988 chevy silverado 2 wheel drive truck with a 5.7 litter. The problem is when ever I drive it to warm up it acts like it is running out of gas. I have changed plugs, wires,fuel filter and yes I even filled it up. Could it be a catalytic converter starting to plug? or am I missing something obvious. |
| have checked for codes yet? it could be a number of things.
| Full Member Join Date: Nov 2006
| I agree with mudseeker, check for codes. The first thing I think of is its possible your induction system is cloged or your mass air sensor is going and the engine is calling for air and not getting it. But like mudseeker said definitly check for codes |
| Tried the old paper clip trick but my check engine light is not working (if its not one thing its anouther) |
| No "Check Engine Light" hmmm.......try replacing your O2 sensor or check for plugged cat. Either way, it's best to get the light fixed. Does it not have "light" or not functioning kind of thing? The reason being is that if its throwing a code it may still be in memory even after you try these suggestions. Don't wanna tell you you have a bad ECM.
__________________ '85 Oldsmobile 442 '93 Chevy 2WD C1500 350 Silverado Extended Cab Shortbed '95 Chevy 4WD K2500 454 Silverado Extended Cab Long Bed |
| Junior Member Join Date: Dec 2006 Location: Paducah, KY
| maybe pcv plugged or vacuum leak? |
| Rough idle and Stutter on acceleration 2003 Tahoe 5.3 Vortec | jnettrecker | Chevy Truck Forum | 17 | 12-16-2006 08:30 AM |
| 95 2500 7.4l running rough | offroad_boy | Chevy Truck Forum | 2 | 04-11-2006 09:45 AM |
| Rough Running | smokejumper0902 | GMC Truck Forum | 3 | 03-13-2006 06:46 PM |
| Engine dying afte running a few mins. on 89 s-10 | Polaris 500 | Chevy Truck Forum | 7 | 01-22-2006 04:05 PM |
| Running rough | Daniel B | GMC Truck Forum | 4 | 12-20-2005 02:50 PM |
