| Headlight Adjustment How do I set the headlights on a 1996 Silverado? The previous owner lowered the front end and not the headlights point downward.........and one off to the side a little bit. |
| i believe the adjustment screws are above the lights, you should be able to see them when the hood is up.
| It looks like a torx bit if i remember correctly. It is a little rod that is right behind the headlight assembly.
| The Little Rod Is Supposed To Be The Side To Side Adjustment Though. It Looks Like A Torx Now That I See It. |
| Drive your truck lights on of coarse at night up to a wall so that you can see when there both at the same height when adjusting them that's how I adjusted mine I also replaced my bulbs with PIAA bulbs much bighter. Make sure that when you adjust them see if you can find a leval spot so both headlights can be at the same height. |
| | #6 | |
__________________ member map add yourself alldatadiy why is it, when i push one for english, i still can't understand the person on the other end? | |
| headlight modification | mudseeker | GMC Truck Forum | 2 | 08-18-2006 05:28 AM |
| transmission adjustment????? | crazyhorse357 | Chevy Truck Forum | 5 | 06-17-2006 09:26 PM |
| 1997 C3500 headlight question | yeeolde48 | Chevy Truck Forum | 8 | 01-22-2006 10:09 PM |
| Any info on aftermarket Headlight assemblies | speadphreak | Chevy Truck Forum | 6 | 12-11-2005 06:21 AM |
| 02 S10 headlight issues | 84ranger | Chevy Truck Forum | 0 | 08-07-2005 02:51 AM |
