| Full Member Join Date: Dec 2006
| 99 S10 2.2l PU Starting problem Newbie to the forum. I purchased a 1999 S10 yesterday with the 4 cyl 2.2l engine. The truck has 159K miles on it. I noticed that the engine needed to crank quite a bit before starting when I test drove it. This morning I want out to showoff the "New" truck to the wife and it wouldn't start. It just cranked but wouldn't fire. Finally got it to fire after about 10 minutes and I could hear it popping from the intake before it cleared up. Which leads me to think that I may have a fuel pressure problem. Questions; Is there a cold start injector on this engine? I don't think there is but asking anyway. Is this truck engine combination affected by knowned fuel pressure regulator or fuel pump problems? I guess I'm going to have get a fuel pressure gauge to check it out. Where is the fuel pump located? In tank? I did notice that the DRL relay located next to the fuel pump relay had pin 86 bend over to disable the DRL. I didn't think that would affect the starting but I'll ask the more knowledgeable member if this could be the problem? Any assistance will be greatly appreciated. |
| | #2 | |
| Full Member Join Date: May 2007
| replace your crank sensor soon,it will fail on you soon with the miles you have.cheap part,easy to install. |
| I'm on a tight budget, may have to wait til it goes.... |
| 2001 Chevy Silverado Z-71 Starting Problem | a5150joseph | Chevy Truck Forum | 1 | 12-03-2006 08:11 PM |
| 99 Chevy starting problem | chevyz71 | Chevy Truck Forum | 2 | 01-24-2006 07:27 AM |
| 97 Tahoe 5.7 liter starting problem | StevesTahoe | Chevy Truck Forum | 0 | 06-07-2005 07:11 PM |
| Problem starting | Keith23 | Chevy Truck Forum | 3 | 03-10-2005 09:43 PM |
