| Junior Member Join Date: Dec 2006 Location: Larryville, Ks
| 2003 Silverado EVAP trouble codes My truck has been sputtering at idle for a while, but runs fine so I replace the fuel and air filters with no change. A few days ago, my check engine light came on. I took it to the auto parts store and they ran the code thing and it says DTC P0449 EVAP Emission Control System Vent Vlv/Sol Malf and P0455 EVAP Emission Control System Leak (large). Any suggestions? I ALWAYS make sure my gas cap is on tight, everytime I get gas. I don't know exactly what the EVAP is, but doesn't it have something to do with vacuum in the tank and recurculating fumes?? I don't really know where to begin here. |
| You can try and just throw parts on it but with the evap system we use a scan tool to comand the purge and vent valves closed and then fill the system with nitrogen and or smoke and search for the leak. So i'm not sure how a backyard mechanic could correctly diag and evap system. Yes you are correct that the fuel tank is a closed system inwhich when comanded the purge valve draws fumes from the tank putting it under vacuum and can control the vacuum with a vent valve which vents the fumes after they go through the charcoal canister. |
| ^^^^I second that.
__________________ '85 Oldsmobile 442 '93 Chevy 2WD C1500 350 Silverado Extended Cab Shortbed '95 Chevy 4WD K2500 454 Silverado Extended Cab Long Bed |
| What does this code mean? DTC P0449 EVAP Emission Control System Vent Vlv/Sol Malf ? Does that mean a vent is not doing what is supposed to do? I thought that I would check all of the wires and connections on everything I could see or feel around the tank. This all happened after it went from being really cold and icy to 60 in 2 days.(gotta love Kansas weather). I don't know if that could have any effect on it or not. |
| | #5 | |
__________________ '85 Oldsmobile 442 '93 Chevy 2WD C1500 350 Silverado Extended Cab Shortbed '95 Chevy 4WD K2500 454 Silverado Extended Cab Long Bed | |
| I might have to take it to the shop to get fixed. |
| 2003 Silverado Wont Start | wff | Chevy Truck Forum | 16 | 11-11-2009 02:52 PM |
| 2003 silverado problem | derspinna | Chevy Truck Forum | 0 | 03-02-2006 03:11 PM |
| silverado -89 fault codes for ABS, RWAL | hempa | Chevy Truck Forum | 0 | 12-10-2005 08:14 AM |
| 2003 silverado | george405 | Chevy Truck Forum | 2 | 12-05-2005 11:01 AM |
| 2003 Silverado 1500HD Brake Rotors | samsonsdad | Chevy Truck Forum | 8 | 07-12-2005 09:05 PM |
