| Full Member Join Date: Dec 2006 Location: Southeast Alabama
| I have a 1990 C1500 with a cruise control problem. It does absolutely nothing! What part is most likely to fail? I'd say the switch? What is the best approach on troubleshooting my problem? |
| could also be a vacum problem. mine coincidently went out while it was at the shop to have the actuater for the 4x4 replaced.
| | #3 | |
| | #4 | |
__________________ '85 Oldsmobile 442 '93 Chevy 2WD C1500 350 Silverado Extended Cab Shortbed '95 Chevy 4WD K2500 454 Silverado Extended Cab Long Bed | |
| Senior Member Join Date: Mar 2005 Location: ontario, canada
| cruise control check your brake switch ...i have a 98 and when it does not work it is the brake switch but then i dont know about a 1990 ...just my 2 cents worth ..........pete
__________________ I am gm all the way ....... black 98 Z71 3 door short box 5.7 |
| I believe there are 4 wires coming off the column for the cruise control. With the key on look for one to be hot. If not look for problem towards fuse / conv center. If got one, hit on for cruise and there should be a second hot. if not = bad switch. If now 2 hots there, check brake pedal switch for hot from there. Really two sw there and on older a vac sw. Get right sw sholud be easy to see which is which. Lots of those switches went bad and was recall for some years. If good and you have a clutch check same thing there. If all that is good, you have problems with controller, or ecm info, etc. Not common. And where you been for 8 months ? LOL Last edited by crabtruck; 08-14-2007 at 06:21 AM. |
| cruise control | vanhal | Chevy Truck Forum | 3 | 12-19-2006 06:09 PM |
| 01 Sierra Cruise & Blower Motor Question | jim5434 | GMC Truck Forum | 4 | 08-25-2006 10:55 AM |
| 2001 GMC 2500 Cruise Control Problem | jim5434 | GMC Truck Forum | 1 | 07-18-2006 01:03 PM |
| Cruise Control Lever 1988 Jimmy | cheesebone | GMC Truck Forum | 2 | 06-27-2006 08:44 PM |
| cruise control | vanhal | Chevy Truck Forum | 1 | 02-11-2006 11:52 PM |
