Old 12-25-2006, 04:59 AM   #1
ehcees's Avatar
ehcees is on a distinguished road
71 Chevy C10: Replace Points > Electronic Iginition?
NEED: Replace Contact Points with Electronic Ignition?
Can you supply manufactuer name/model# & place to buy upgrade piece that replaces factory points setup? Distributor is stock. No other modications are wanted. Only want to place an electronic part in the same position of factory contact points in factory distributor.
1971 Chevy Cheyenne 10 Fleetside Long bed, 350 V8, AT, AC. Built: 5/12/1971 Fremont, CA. Sold new: Kelsey & Sons Chevrolet, 390 HWY 246, Buellton, CA. Order# TNL098 Zone 34, Dealer 270. Customer Order. Weight 3677 (unloaded) Factory AC.
Attempt to post photo gets:
Your file of 224.5 KB bytes exceeds the forum's limit of 150.0 KB for this filetype.
Glove box door Service Parts Identification label States-The special equipment listed below has been installed on this vehicle. For proper identification of replacement parts be sure to specify the applicable option numbers.
Option no. & Descriptions: Important: Retain this plate as a permanent record.
W/Base 127
B85 Belt Molding
F52 Front Shock Absorber (bumper guards)
LS9 350 CU IN V-8 Engine (4 bbl)
N40 Power Steering
VK2 Tool & Stowage Box
Z84 Custom Sport Truck
621 Saddle Vinyl Custom Trim
A11 Tinted Glass
C60 4- Season Air Cond
G70 R Susp- Leaf Spring
M49 Turbo Hydra-matic
U63 AM-P/Button Radio
Z53 Amp-Oil-Temp Gauge
463 White & Ochred (yellow sort of)
ehcees is offline   Reply With Quote
Old 12-25-2006, 05:19 AM   #2
ont_guy_38 is on a distinguished road
I know what your looking for i have seen this before but that was a lot of years ago they had that conversion kit ,i,m taking it you want the truck to look stock otherwise would be way easier to just replace it with a newer H.E.I system.Found one website on it might be an old site but here ya go http://www.davessmallbodyheis.com/ .Also check out page 30 here http://go.mrgasket.com/pdf/MALLORY.pdf
ont_guy_38 is offline   Reply With Quote
Old 12-25-2006, 08:14 PM   #3
Chevy808's Avatar
Here's a website: http://pertronix.com/home.htm
'85 Oldsmobile 442
Old 12-25-2006, 09:43 PM   #4
n brock is on a distinguished road
just go to your local auto parts store. i did the same thing on my boat. i think it was about 30 bucks
n brock is offline   Reply With Quote
Old 12-26-2006, 04:21 AM   #5
ehcees's Avatar
12/26/06> Respondents text with ehcees replies inserted below:
ont guy 38: I know what your looking for i have seen this before but that was a lot of years ago they had that conversion kit. I am taking it you want the truck to look stock otherwise would be way easier to just replace it with a newer H.E.I system. Found one website on it might be an old site but here ya go http://www.davessmallbodyheis.com/ .Also check out page 30 here http://go.mrgasket.com/pdf/MALLORY.pdf
ehcees: Correct, I want to maintain the original stock distributor & if available, just screw a component into the same space that points reside. No need to change out the distributor, looks original & no space conflicts from larger HEI distributor. Will check the web sites provided & report findings. Thanks for helping.
Chevy808: Here's a website: http://pertronix.com/home.htm
ehcees: A few years ago I attemped to contact these folks. Web site was cryptic & lacking any contact us ability. Two faxes got no reply. Do you have a toll free number and/or an E-mail address for Pertronix? Thanks for the lead.
N brock: just go to your local auto parts store. i did the same thing on my boat. i think it was about 30 bucks.
ehcees: In past did call several local auto parts stores. New HEI distributor was availabe. No component for just replacing points in stock distributor with electronic was available. Will try again. Can you tell name of parts store that had the item for your boat? Reply appreciated.
Old 12-26-2006, 08:26 AM   #6
Chevy808's Avatar
I guess the technical support board is under construction. Try the auto parts store again like n brock mention and ask for pertronix. I know they have a catalog with phone numbers or email address or just order from them. Strange, on the oldspower board, a lot of the members were able to get it for their 442's.
'85 Oldsmobile 442
Old 12-28-2006, 04:40 AM   #7
ehcees's Avatar
Points Module Replacement Search Update
12/28/06 ehcees update:
Pertronix web site is same as in 2003 with no “contact us”, E-mail address or toll free#. No parts listing either. Seems like talking to Customers is not available & unacceptable to ehcees.
Local Hi Performance shop does sell Pertronix module replacement for $80. My 1971 C10 is all stock parts & Hi Perf shops are always high priced. I’m cost effective & Hi Perform is not.
Advance & Auto Zone (known by other names in different states) do not offer the item, when called yesterday.
Message has been sent to Mr. Gasket & awaiting reply. First step, for me, is too see how any company handles Customer inquiry.
www.davessmallbodyheis.com/ offers: General Motors window type V-8 all makes Full HEI conversion — $175.00 & MSD trigger conversion — $135.00, which seems overpriced & again the Hi Perform deal.
The search continues.
95' Chevy 3500 strong/ weak points wmiller Chevy Truck Forum 1 08-08-2006 10:38 AM
