Old 12-26-2006, 09:40 AM   #1
m-3mike is on a distinguished road
Shaking 1995 Silverado
I'm hoping someone can help me out. I have a 1995 Silverado, 2wd, 5.7 with 180k miles. I've replaced the complete brake system and still get a shaking upon braking. It feels like the truck is coming apart. I used AC Delco parts, I've lubed the driveshaft yoke, the front suspension has no excessive play. It almost feels like the ABS is kicking in. It's not as noticable with a load or towing.
Help, I love the truck and hate to lose.
Mike
m-3mike is offline   Reply With Quote
Old 12-26-2006, 01:49 PM   #2
joshnkelly is on a distinguished road
mike,
It could be a brake line collapseing or a bad caliper. Both items are really cheap for your truck.
joshnkelly is offline   Reply With Quote
Old 12-26-2006, 01:57 PM   #3
Chevy808's Avatar
Mike
If you have ABS did you code? Might want to check the rear brakes for slipping.....the gear oil or possibly fluid getting on the shoes. Sounds like you're not getting any help slowing down from the rear. The front brakes is taking all the load (which is too much) to slow you down.
'85 Oldsmobile 442
Old 12-26-2006, 02:06 PM   #4
The calipers are new, brake hoses are new, Master Cylinder is new, wheel cylinders, shoes, drums etc. Replaced the rear hard line, rusty. No ABS light on.
Mike
Old 12-26-2006, 08:35 PM   #5
Chevy808's Avatar
Mike
Did you take it to a shop or did you do the brake overhaul yourself? Was the ABS system bled correctly? How long ago was the rotors replaced? How much did the rotor cost? This sort a determines the quality of it. I brought cheap rotors from checkers and it didn't last 6 months. It warped because the metal was of cheap grade. Paid for a heavy duty set a $100 each from a reputable brake store. Problem solved. In my case, I've replaced all the front parts too.
'85 Oldsmobile 442
Old 12-27-2006, 07:35 AM   #6
I own a Shop, I've had my best guy on it. I"ve used only AC Delco parts. That's my I'm so frustrated. I've gone 40mph cut off the truck in neutral and it still does it.
Old 12-27-2006, 07:38 PM   #7
Chevy808's Avatar
Wow, you eliminated the guess work huh (major brake overhaul). Try this then if you haven't tried it yet. Unplug the ABS I think it's the red and white harness. Take it for a spin and see what happens. Your truck will be just be on regular braking without the ABS.
'85 Oldsmobile 442
Old 12-31-2006, 06:54 AM   #8
Mike
Try changeing the transmission fluid and filter. Mine was doing the same thing and I have replaced everything you have plus some. I changed the trans. oil and filter and it fixed the problem.
Old 01-01-2007, 06:39 AM   #9
I have, I think it might be the trans. I just want to hear it from another Truck owner before I rebuild the trans.
Mike
Old 01-02-2007, 06:13 PM   #10
dstrick32 is on a distinguished road
Before you rebuild the trans have the TCC solenoid checked out!!
95 Ford F-150XL 5.0 Automatic
92 Chevy Silverado 5.7 Automatic
94 Toyota Ex-Cab 4X4 3.0 Automatic
dstrick32 is offline   Reply With Quote
1995 Silverado ignition timing Mark Chevy Truck Forum 10 11-15-2009 07:35 AM
Chevy Silverado 3/4 Ton AdmnPower Chevy Truck Forum 6 12-03-2006 09:36 PM
1995 Chevy Silverado 1500* 5.7,at*87,000 Miles mrhaney Truck Classifieds 2 09-08-2006 05:43 AM
90 silverado sensor? snake eyes Introductions 3 08-08-2006 06:24 PM
95 Silverado speedo help lwin517 Chevy Truck Forum 0 02-01-2006 08:39 PM
