Old 12-26-2006, 09:02 AM   #1
annerupert is on a distinguished road
1997 Chevy PU problem leak into heater fan
Hello,
Have a 1997 Chevy Cheyanne Pick-up truck. Having a problem with water (not anti freeze) leaking from outside into the heater fan. This water freezes during winter at times causing fan to become frozen. Later resulting in only high speed fan to work.
Suspect water leaking from outside by wiper area, but not certain. A local garage suggested it could be a seam on heater. At a loss at this point and would like some suggestions. Will be grateful for any information.
Has anyone had this problem before?
Thanks
Anne
annerupert is offline   Reply With Quote
Old 01-01-2007, 11:39 PM   #2
deoncollins69 is on a distinguished road
Originally Posted by annerupert
Hello,
Thanks
Anne
The water is comming from the cowl area just under the plastic piece between the hood and the winshield. My 97 filled up with water when it rained hard. I took the cowl cover off. filled the screw holes with silicon and screwd it back down. Problem fixed for a while.
deoncollins69 is offline   Reply With Quote
Old 01-02-2007, 07:20 AM   #3
Chevy808's Avatar
Wow! that's not normal. Sort of like a design flaw from the factory. Check to see if there's a recall.
'85 Oldsmobile 442
Old 01-02-2007, 04:39 PM   #4
Yeh that is the fix on the passenger side there is a screw that from the factory has sealent on it which is directly above the fresh air inlet which goes straight into the heater box and if anyone has had the plastic cowl off and did not reseal the screw or stuck the screw in the wrong hole it causes water to enter heater box. Very common problem after a windshield is replaced by someone other than a profectional.
Old 06-04-2007, 10:38 AM   #5
Shox's Avatar
Shox is on a distinguished road
Thumbs up water leak
Nice response Deon and GM! You guys are Super!! Thats the kind of infomative, right on, info that makes this site "Top Notch". I'm sure Anne is very appreciative. I just wanted to give you a little extra cuddos
Shox is offline   Reply With Quote
76 Chevy 454 - massive oil leak in rear of engine MrDavidOgle Chevy Truck Forum 22 06-24-2009 07:03 PM
Heater Problem bubba8167 Chevy Truck Forum 5 05-27-2006 11:09 PM
1997 chevy tahoe gage light problem bajaboy Chevy Truck Forum 5 03-23-2006 07:58 AM
chevy s10 fuel injector problem... rrodriguez190 Chevy Truck Forum 8 10-29-2005 11:23 PM
Chevy Truck heater? toadross Chevy Truck Forum 1 08-15-2005 09:55 AM
