Old 12-30-2006, 09:07 AM   #1
liljohnny is on a distinguished road
remote starter
just had a remote starter installed by a professional car audio place in a 2003 silverado when you start the truck with the remote, the passlock dash light comes on after you insert the key and it stays on. if you start the truck with the key the pass lock does a test and then shuts off.is this normal to have the passlock light stay on when using the remote to start
liljohnny is offline   Reply With Quote
Old 12-31-2006, 06:48 AM   #2
joshnkelly is on a distinguished road
Go back to the shop and they can wire it in differently. There are a couple of was to wire it in on your truck. Don't try to fix this yourself or you could kill the computer.........
joshnkelly is offline   Reply With Quote
Old 12-31-2006, 01:47 PM   #3
the shop said they would make phone calls on tuesday to see why this light only comes on when i use the remote . they installed it ,they can fix it
Old 01-03-2007, 05:03 AM   #4
mod-o-tator
sounds like they tried to shortcut their way around the factory alarm and save them selves some money.
member map add yourself
alldatadiy
Old 01-03-2007, 01:14 PM   #5
dstrick32 is on a distinguished road
I'm personally not a big fan of aftermarket remote starters and alarms. Even those installed by so called professionals that don't know very much more than we. Ask any professional GM, Ford or other tech and they will tell you that this is just the beginning of your problems. If it wasn't done by the factory when vehecle was assembled it's not worth the trouble!! Just another wrenchhead's opinion.
95 Ford F-150XL 5.0 Automatic
92 Chevy Silverado 5.7 Automatic
94 Toyota Ex-Cab 4X4 3.0 Automatic
dstrick32 is offline   Reply With Quote
Old 01-09-2007, 04:50 PM   #6
got the truck back and everything is fine, they had to replace the module
Old 04-29-2007, 02:43 PM   #7
kjskoncepts's Avatar
kjskoncepts is on a distinguished road
I have a 2000 chevy s10 extreme. Standard doors and windows no chip in key. Replaced steering column and key. New fuel pump. I think the passlock wont let my truck start please help. No trouble codes exept low fuel tank pressure sensor. Pump comes on fine and she wants to start but the passlock keeps shutting down my injectors. cant I bypass it without a remote starter by using a toggle switch? From what Ive read so far it should just be the yellow wire coming out of my key cylinder that needs to be spliced and the toggle switch added to it is this correct and should it stop the no start condition or do i also need the computer reprogramed?
Last edited by kjskoncepts; 04-30-2007 at 11:44 PM. Reason: bad typos and added some more questions
kjskoncepts is offline   Reply With Quote
Old 04-29-2007, 02:44 PM   #8
sorry about the typos but in a hurry to get to truck before they tow it!!!help
Starter problem, need help. MadMazda Mazda Truck Forum 6 01-21-2007 09:52 AM
Remote Lock Opener Problem dodidupa Dodge Truck Forum 0 12-11-2006 10:59 AM
starter problems ChevyTrucker Chevy Truck Forum 11 07-27-2006 10:19 AM
programing door key remote 99 denali SSS racing GMC Truck Forum 1 06-11-2006 08:35 PM
1992 GMC Suburban Starter Treecem GMC Truck Forum 4 05-05-2006 12:23 PM
