Old 01-07-2007, 09:43 PM   #1
lkaveman is on a distinguished road
94 chev automatic tranny troubles
i just bought a 94 s10 blazer 4.3 auto with 4wd have 2 problems gas in oil running rich i hope its fuel regulater has central port injection spendy other problem is in overdrive when shifting into 3rd gear its like going into neutral ,in regular drive 1st and 2nd is fine but wont shift into 3rd, reverse works good dosent seem to slip at all in 1 or 2 . Does it sound like my 3rd gear is toast needing new tranny or hopefully a modulator is it possible a vacuum leak could cause both fuel and tranny problem i hope i dont have remove tranny but maybe its time to learn to rebuid automatic thank you if you have any suggestions
lkaveman is offline   Reply With Quote
Old 01-08-2007, 07:31 AM   #2
03chevy's Avatar
there is two sencers in the tranny when you remove the pan. i would change the fluid and filter and when you do you will see them. i have a friends truck i had to change because it wouldn't take a nother gear. they are very easy to remove and put back in.
94 chev automatic tranny troubles lkaveman Chevy Truck Forum 0 01-07-2007 09:41 PM
Speedo Tranny Wiring? Problem TMHark Chevy Truck Forum 4 08-02-2006 08:03 AM
New Tranny!!! Which Fluid do I use??? YngPiggyZ71 GMC Truck Forum 13 04-09-2006 07:00 PM
88 2500 tranny question littlekings Chevy Truck Forum 2 12-15-2005 05:21 AM
