| Junior Member Join Date: Dec 2006
| E-brake problem I've got a buddy with a '94 Cheyenne 4x4 and the E-brake cable was broken. He put a piece of cable in the spot where broken because NOBODY, not even the local GM dealer could find him a replacement cable. Now the cable holds but the actual pedal slips. Are the teeth worn on the pedal or what's the deal? Thanks very much for any help.
__________________ Chris Brown 1988 Silverado 4x4 1989 Silverado 4x4 1976 small block 350 that needs to go in something! |
| it might be. but check to see if there's play in the pedal for movement that could be the prob. if there is go to the junk yard and get one for little money. |
| | #3 | |
__________________ '85 Oldsmobile 442 '93 Chevy 2WD C1500 350 Silverado Extended Cab Shortbed '95 Chevy 4WD K2500 454 Silverado Extended Cab Long Bed | |
| | #4 | |
| Under the truck Quote:
__________________ Chris Brown 1988 Silverado 4x4 1989 Silverado 4x4 1976 small block 350 that needs to go in something! | |
| | #5 | |
| Brake problem on 1996 K3500 | mjeltema | Chevy Truck Forum | 4 | 12-27-2006 07:08 AM |
| front brake problem 03 Ford f250 | hdkidd | Ford Truck Forum | 2 | 12-13-2006 09:17 AM |
| front brake problem 03 ford f250 | hdkidd | Introductions | 0 | 12-12-2006 09:14 AM |
| brake light problem | ramdodge | Dodge Truck Forum | 5 | 09-18-2006 07:05 PM |
| Dodge truck brake problem | BlakRam | Dodge Truck Forum | 3 | 04-02-2006 04:27 PM |
