| 1994 chevy 1500 cam swap a friend of mine just done a cam swap in his 94 chevy 1500. he had a ticking coming from under the hood that sounded like a rockerarm he thinks it is supposed to do it but i have heard different can anybody shead some light on the subject |
| it should not tick, a lot of trucks with a lot of miles do, if it started after he did the cam swap it may be wiping out a lobe, and if that's the case it may trash his whole engine due to the metal in the oil. |
| What was the last cam specs and what is the specs of the current cam?? What is the new valve clearance or lash for the new cam? It may need adjustments.
__________________ '85 Oldsmobile 442 '93 Chevy 2WD C1500 350 Silverado Extended Cab Shortbed '95 Chevy 4WD K2500 454 Silverado Extended Cab Long Bed Last edited by Chevy808; 01-10-2007 at 10:17 PM. |
| did he change the lifters while he did the cam? it could be a lifter tick. and it could be getting ready to go out |
| i am also wondering about the lifters. always install new lifters with a new cam. if it is a cam from another engine, use those same lifters in the same holes that they came from. does he have correct valve clearence between it and the rockers?? |
| Senior Member Join Date: Dec 2006 Location: Bremerton, Washington
| did it tick before he changed the cam?
__________________ 1979 Crew Cab Chevy 1 Ton Dually 454 |
| 1994 Chevy Fibrating | joshnkelly | Chevy Truck Forum | 4 | 12-30-2006 08:08 AM |
| 1999 Chevy 1500 tune up | dokutman | Chevy Truck Forum | 2 | 12-07-2006 03:55 PM |
| '06 Chevy 1500 electronics | davidgk | Chevy Truck Forum | 1 | 08-06-2006 08:12 PM |
| Motor in my 1994 Dodge Ram 1500 4x4 | mikejr1226 | Dodge Truck Forum | 12 | 02-22-2006 09:59 AM |
| 1990 1500 engine swap 454 to 350 | jchcomputers | Chevy Truck Forum | 2 | 02-01-2006 07:45 PM |
