| Senior Member Join Date: Oct 2006
| 1994 Chevy 350 Starter Hey folks, my 94 z71 with a 350 has starter problems, I think. The other night I stopped at the pizza joint and when I tried to start up and leave, it just made one good click. I tried twice more and on the third try it struggled but did start. I thought I had a battery problem. I got it home and it won't start with a good battery. It just makes one good click. I assume I need to replace the starter, but I want to make sure first. thanks, Jeff |
| Could be the solenoid on the starter. go to a bone yard if it is. I'm sure you can get one cheap. Before doing that try jumping the starter with a screw driver to see if the solenoid engages. It could be a wiring problem. check to see if maybe a wire is burned from manifold and shorting out
| hayden has some good info but i would try the easiest first. i think you probably just need to clean the studs at the starter and make sure every thing is tight. i had this problem with our 95 chevy van, cleaned the studs and wires and has worked fine since. |
| 1994 chevy 1500 cam swap | jag9177 | Chevy Truck Forum | 5 | 01-13-2007 06:41 PM |
| 1994 Chevy pickup electrical problems | seniorjudge | Chevy Truck Forum | 4 | 01-02-2007 07:17 AM |
| 1994 Chevy Fibrating | joshnkelly | Chevy Truck Forum | 4 | 12-30-2006 07:08 AM |
| 1994 Chevy S10 Failed emission test | mamabear | Chevy Truck Forum | 6 | 10-11-2006 02:11 PM |
| 1994 chevy truck electrical problems | ohio larry | Chevy Truck Forum | 0 | 12-25-2005 09:09 AM |
