Old 01-16-2007, 01:11 PM   #1
klink70 is on a distinguished road
Smile 94 K1500 350 engine rebuild
I am in the process of rebuilding my 94 chevy's engine. It's a throttle body injected 350(5.7L). The block has the mechanical fuel pump mount cast into it, but it is not milled out. My questions are, does this block have the same bearing dimensions as a pre '87 block(cam, rod & main)? Are the cylinder bores the same? Basically is this just your standard late model small block? The crane cams spec sheets all say '57 to '87 engines. Also can I move up to a mild rv cam for towing and off-road without affecting the computer or TBI system? Once again the crane cams spec sheets all say "pre-computer". When I shop for a cam at Jegs mail order it lists the cam I want as 262c.i.-400c.i. '55-'98
klink70 is offline   Reply With Quote
Old 01-16-2007, 03:51 PM   #2
all bearing dimensions are the same. yes you can go with a mild cam. I'd call the crane cam tech line tell them what you have and they can point you in the right way.
Old 01-16-2007, 07:20 PM   #3
Thanx for the input, Mr. Wanye! What part -o- Texas are you from?
Old 01-16-2007, 07:38 PM   #4
Chevy808's Avatar
Yes. Just watch the duration @ .050 specs. keep it under 218* on both the intake and exhaust. Computer controlled vehicles probably, if not, only handle the next step up of the stock cam. Too much duration will cause a havoc on your ECM.
'85 Oldsmobile 442
Old 01-17-2007, 09:16 AM   #5
I dwell in the DFW area.
1996 K1500 engine swap? Charles1221 Chevy Truck Forum 1 10-02-2006 02:27 AM
How best to remove 1972 Chevy 4x4 engine? rstricklin Chevy Truck Forum 3 08-27-2006 04:36 AM
WTB 3.0 v6 for a 92runner jvmin Truck Classifieds 15 07-18-2006 05:57 AM
Carb to TBI engine swap klink70 Chevy Truck Forum 5 02-17-2006 09:54 AM
Engine Identified! Anyone know specs? klink70 Chevy Truck Forum 1 01-30-2006 09:07 PM
