| 2001 2500HD 6.0L 4x4 Power Issue - Lean Fuel I have a 25% lean fuel reading on the left injector bank of my 6.0 L engine. It happens at about 40 - 60 mph on road driving. I have changed fuel pump, fuel filter, plugs, wires, air filter, O2 sensors, checked injector pump and pressure. Didn't solve the problem. Swapped the left bank injectors with the right bank to see if injectors are the problem but problem stayed on left bank so injectors are fine. The computer is throwing no codes. Any thoughts on what else I may be missing. Thanks Anthony |
| a problem with the computer. |
| All the lean fuel conditions i have ever dealt with was from a vacuum leak of some sort.check all hoses carefully,take some ether and spray a light mist along each side of your intake manifold,along the base of your throttle body or carburator any other place that can suck air. Make sure your pvc valve is not letting to much air bypass.test egr valve and make sure that pendelum is sealing also check egr gasket and be sure it is not burnt between the two ports and is tight.last thing i can think of if you have power brake booster be sure you dont have a ruptured diaphram sucking excessive vacuum.also any vacuum hosing going to cab for ac and heat controls.when you find the leak it should correct your lean condition. |
| checked injector pump and pressure, Hmmmmm?? duel fuel engine? Sorry had to, as sometimes we do on this forum what was the fuel pressure? is the lean condition reading off a scanner during a drive cycle or sitting? check the voltage reading on the left bank injecters for variation and confirm the fuse for the left bank is clean
| leo, date?
| that is the second time this week. i believe leo is making a comeback. |
| Fuel System Issue - 1989 4x4 4Runner | HKforte | Toyota Truck Forum | 1 | 01-11-2007 06:41 AM |
| '91 2wd Fuel Issue | J-Bob Bigz | Chevy Truck Forum | 3 | 12-08-2006 09:24 PM |
| 2001 chevy 2500 Fuel gauge | teampenner | Chevy Truck Forum | 10 | 08-15-2006 03:08 PM |
| Best mileage muffler change for a 2001 6.0L 3/4 ton | LTTruck | Chevy Truck Forum | 0 | 03-25-2005 11:07 AM |
| Deka Batteries Teams with Nuvera Fuel Cells to Develop Advanced Power Options for Industrial Trucks (PR Newswire via Yahoo! Finance) | trucknews | Truck News (headlines) | 0 | 01-06-2005 03:30 PM |
