| Intake 5.7 There seems to be something holding my upper and lower manifold together from the inside. All bolts are out. Any ideas? Thanks. |
| upper and lower manifold?? the intake manifold is one piece. can you please be more descriptive. |
| I have a 99 suburban with the 5.7. It has a intake that is made of 2 peices. The lower half looks like a normal intake except it is only 2 inches high and another plasic smaller manifold bolts on top of it. |
| Hope you do not have two pieces of intake manifold. They can be stubborn sometimes, usually has a fair amount of silicone around the corners where it meets the block / heads. Be sure the dist. is out, and the valve covers are off. They do get in the way. Then I usually pry slightly between the intake and the block, in the center just above the water pump. It will not take too much to get it to "pop". The rest is gravy after that. You will be amazed at how heavy that thing is. |
| no he's right. the 350 vortec had a 2 piece manifold. as for it not coming apart can't help you. I know they will but have never done it.
| i've got a 99 burb with the 5.7 too, i'll take a looka t it tomorrow and see if i got any advice... why are you pulling the intake jw?
| I am leaking antifreeze from the gasket on the back side. The plastic top manifold is loose but there seems to be something inside holding it down and I don't want to break something by pulling to hard.? |
| take the dis. out and take the bottom off dont worry about takin the top one off. i had one leak from the lower man. and its passanger side back.
| Thanks. I think some of the bolts for the lower are under the upper manifold. I can only see 8 bolts, 2 in each corner. The chiltons manual show s 12. ??? |
| there are only 8
| cold air intake | chevy4x42 | Chevy Truck Forum | 3 | 01-25-2007 10:20 AM |
| Cold air intake 99 ranger | AdmnPower | Ford Truck Forum | 0 | 12-27-2006 06:43 AM |
| Air Intake? | tec_41 | GMC Truck Forum | 7 | 08-24-2006 09:37 PM |
| intake manifold/TBI | scottie | Chevy Truck Forum | 0 | 01-26-2006 01:23 PM |
| What is a good Cold Air Intake? | rickards | Chevy Truck Forum | 12 | 12-07-2005 06:01 PM |
