| Junior Member Join Date: Feb 2007
| Lifting the front I've got an 06 Z71 and want to lift the front to level the rake out. I've been reading about replacing the torsion keys and a little on spring spacers. What are the advantages/disadvantages of these? Any advice on this is greatly appreciated. |
| Do a search on torsion key lifts. You'd be suprised on the posts you'll find....there's a bunch of them.
__________________ '85 Oldsmobile 442 '93 Chevy 2WD C1500 350 Silverado Extended Cab Shortbed '95 Chevy 4WD K2500 454 Silverado Extended Cab Long Bed |
| You will be limited to torsion keys, or a full on lift kit. You do not have conventional springs up front that spacers will work for. The downside to torsion key lifts, are that it limits travel extension. depending on how far you crank up the torsion bars after the keys are installed. This will make for a funny ride when a big bump is hit, and the suspension is topped out. A-arm suspensions have limited travel, and by lifting a vehicle within that travel limits the use of a full suspension cycle. |
| Senior Member Join Date: Dec 2006 Location: Illinois
| My neighbor adjusted his tortion bars a few turns and now his truck is level. Took him 10-15 mins tops
__________________ Ashley My first truck was a 1988 Chevy 1500 with the 305 My new truck is a 1997 GMC 1500 with the 350 |
| Thanks to all who replied. I will research the torsion lift a little more in depth. Thanks again for the insight. |
| Need Recommendation on Front Shocks | kacharley | Dodge Truck Forum | 3 | 01-16-2007 07:57 AM |
| FS: full-size Chevy/GMC grey front bench, rear separate | ayejay | Truck Classifieds | 7 | 06-30-2006 04:16 PM |
| Front Driveshaft | guidorr73 | Dodge Truck Forum | 10 | 03-16-2006 05:00 PM |
| lifting the front end on 05' GMC sierra 4by4 | mikev4954@msn | GMC Truck Forum | 2 | 11-14-2005 03:11 PM |
