| Junior Member Join Date: Feb 2007 Location: kentucky
| 88 chevy instrument cluster hi ..im the new guy and i just bought a 1988 chevy 1500 truck and the speedomiter,gas gauge, oil gauge dont work, also it has a 4sp.trans. and when i pull it down in drive the needle stays in the park position.. any ideas on how to fix it or how to at trouble shoot it to see whats wrong with it...thanks guys |
| so, basiclly your driving down the highway and the instrument cluster thinks the truck is in park with the engine off. i would check your fuses first before you start digging to deep. |
| Senior Member Join Date: Dec 2006 Location: Illinois
| Haha I have the same truck Same year and the same Problem!!!
__________________ Ashley My first truck was a 1988 Chevy 1500 with the 305 My new truck is a 1997 GMC 1500 with the 350 |
| well i would rather fix it than just deal with it..theres got to be a fix ..if its not a fuse problem would a new cluster fix it...thanks |
| no help huh... |
| Senior Member Join Date: Nov 2005
| try tracy martins, How to diagnose and repair automobile electrical systems. You can get it on amazon for around $16. All other electrical books that I have read are vastly inferior. I have been able to fix all my and my friends electrical problems since reading it. The fact that all the gages do not work means to me that you are either not getting any voltage to the gages or you do not have a ground. Get a good wiring diagram for your truck (that year) and a voltmeter and it should be fairly straightforward. |
| thanks for the advice.. i will check it out... |
| You might want to cave in and visit a local Chevy dealer and have it diagnosed. It sounds like a power failure or wiring failure. With everything out it should be fairly obvious to a trained GM mechanic. Could be simple. Good luck. |
| True Chevy Lovers Help Me Please!!! Y Is Chevy Better Than Ford?! | chevygirl4life | Chevy Truck Forum | 81 | 03-09-2008 11:26 AM |
| Question Chevy vs GMC | Truck_Man | General Truck Forum | 63 | 04-16-2007 09:15 PM |
| Gauge Cluster Question??? | 92BlueZ71 | Chevy Truck Forum | 6 | 12-04-2006 07:22 AM |
| instrument panel | truckpower | Chevy Truck Forum | 2 | 02-28-2006 02:41 PM |
| 1989 chevy value | 396chevy | Chevy Truck Forum | 6 | 09-27-2005 10:23 PM |
