| Junior Member Join Date: Feb 2007 Location: bovina tx
| hi ive got a 3speed 350 trans and i have a big leak at the point that the speedometer connects to the trans on the bullet could any one give me some clues why and how to fix it. |
| Full Member Join Date: Dec 2006 Location: Hartland,Minnesota
| The speedo. gear assembly is held in by small bolt and retainer,remove that and there will be an 0-ring you can replace, that should fix the problem. |
| yall are going to laugh but when i first read the title, i thought, how does a speedometer leak?? is that anything like running low on halogen in your headlights?? dont know why i thought that. when removing the gear, remember that it is a plastic gear and to not get froggy with it. |
| | #4 | |
| Senior Member Join Date: Nov 2006 Location: SW PA
overfill a speedo!
__________________ Peter '03 Silverado 2500HD LS XC SB 8.1L/Allison 3.73LSD 4X4 3/3 drop | |
| make that three.
| There is actualy 2 seals for the housing. There is an oring like the other guy posted around the speedo housing and there is a seal inside the housing where the cable goes into that can also leak. While your in there and removing it replace both. |
| thank yall for the help but i think the inner sleve is gone so im gonna have to replace it but thanks any way ill check the o ring and see if its still good |
| 76 Chevy 454 - massive oil leak in rear of engine | MrDavidOgle | Chevy Truck Forum | 19 | 10-07-2007 01:46 PM |
| speedometer | ChevyMan4Life95 | Chevy Truck Forum | 11 | 09-15-2006 08:33 PM |
| Ford Speedometer acting funny | stalcut | Ford Truck Forum | 8 | 08-13-2006 10:58 AM |
| Speedometer plug location | Hayden | Chevy Truck Forum | 3 | 06-25-2006 05:22 AM |
| Help Power steering leak | kruszka | Chevy Truck Forum | 9 | 05-05-2006 11:50 AM |
