Old 03-02-2007, 01:11 PM   #1
nealsw is on a distinguished road
454 conversion finally!!
Changing from a 305 to a 454, 67K mile 1984 chevy 4x4, original owner, perfect truck (other than the 305) Any help on anything/ hidden problems on this conversion please... Also ideas on acc. brackets with A/C. Want to stay stock looking, I think??
nealsw is offline   Reply With Quote
Old 03-02-2007, 02:04 PM   #2
Sounds like a great upgrade. Is that trans gonna be up to the task?
I can only wonder about the weight of the 454, ( I assume with iron heads, and intake, ouch heavy), and the torsion bars. The diameter of the bar might be questionable. It is going to require quite a bit of pre-load (tension) to give the truck the altitude it needs to stay level. With that much pre load, you might run the risk of breaking a bar with the added weight. I can also see a heavier drivetrain in the future, pretty sure that the little axles are going to struggle with the added torque of that "Fat Rat"
Should be a fun truck though, keep us posted on the results.
Old 03-02-2007, 05:53 PM   #3
84 should be straight axle eh?
Old 03-03-2007, 01:43 AM   #4
Missed that altogether mrjohnwayne! Somehow I saw a completely different year!
Wasn't even drinkin, man that is bad...........
Old 03-03-2007, 09:32 AM   #5
hey it happens!
Old 03-03-2007, 06:35 PM   #6
0425004x4's Avatar
0425004x4 is on a distinguished road
454 swap
You will need to upgrade to the 3/4 or one ton springs shocks etc. The trans will hold up if the motor is stock with a mild perf. rebuild. The stock axles will also hold if the motor is basically stock and you stay 33" and under tires. It should be a blast because it can be built with stock parts and no fabrication needed.
0425004x4 is offline   Reply With Quote
Old 03-03-2007, 06:47 PM   #7
Thanks
I have already changed to Big Block springs up front, then raised the rear 1". Trans waas just beefed up . Thanks for all the info.
« CV axle help | Help »
Hello, Need help about a possible engine conversion? bishopj76 Introductions 2 07-31-2006 07:55 AM
95 Chevy Conversion Van Mckheean Truck Classifieds 7 07-08-2006 07:31 PM
2wd to 4wd conversion csramsey640 Chevy Truck Forum 6 07-05-2006 11:49 PM
Need Infor for 1989 305 to 350 conversion ApplianceGuy Chevy Truck Forum 8 05-31-2006 11:02 AM
97 4.2 v-6 conversion Goatman247 Ford Truck Forum 5 03-17-2006 07:54 AM
