| I need help!!! I am trying to install a column shifter in my 66 chev pick up, The shifter is out of 66 gmc, that had a powerglide. Am I going to be able to make it work with the Turbo 350 I am trying to mate it to? Will it be able to shift into all gears correctly? |
| You should have little problem with the amount of throw, (travel) in the linkage. Aftermarket companies have new linkages for this, as well as new identification glass that shows 3 speed instead of two speed. Looks nice to have the pointer inside the cab point to gear you have selected. I use a 700r4 in my 57' chev that originally had a p-glide, and the 700 has an extra detent. The stock shift lever works well. |
| Thanks, 75k30 Thanks for the info, It makes feel better hearing from someone who has actually done this. |
| Column Shifter problems | low budget | Introductions | 1 | 03-11-2007 11:38 PM |
| anti-theft steering column collar | 93Silverado | Chevy Truck Forum | 2 | 01-23-2007 06:22 AM |
| Guy Problems | Dakotah | Off-Topic | 25 | 04-22-2006 09:58 AM |
| 4 Wheel Drive Problems | 92BlueZ71 | Chevy Truck Forum | 7 | 03-12-2006 03:22 PM |
| 98 electric problems | 98Z71 | Chevy Truck Forum | 4 | 08-20-2005 07:39 PM |
