| Junior Member Join Date: Mar 2007 Location: New Castle, PA
| I Have A 1991 Chevy S-10 Pickup, 2.8 V6, Manual Transmission, 2WD. I Am Have Hardly No Vacuum. Can Some One Help. One More Question I Have This Round Metal Cup Like 3in. Round By 1in Thick. Like Right Behind My Power Steering Pump/Resavor. It Connects To A Hose And The Metal Thing Got A Filter In It And Has Little Holes Around The Outside Of It. I Took It Off And I Would Guess Its Supposed To Suck Air. I Get Nothing. What Is This...
__________________ Eric Ritter |
| | #2 | |
If you have direct port fuel injection, then it may not be a vacuum problem, but a bad injector. | |
| you can find a vacuum leak by spraying starting fluid in small amounts around the engine compartment while the motor is running. When it revvs higher, you have found your vacuum leak. Some people like carb cleaner and it is probally safer, but it causes the motor to die down a little when it is introduced to the motor, but it is not as pronounced as starting fluid.
| 1997 Chevy PU problem leak into heater fan | annerupert | Chevy Truck Forum | 4 | 06-04-2007 11:38 AM |
| a/c problem 05 chevy | curly red | Chevy Truck Forum | 3 | 09-06-2006 01:27 PM |
| vacuum problem | worm | Chevy Truck Forum | 3 | 03-29-2006 09:00 PM |
| 1997 chevy tahoe gage light problem | bajaboy | Chevy Truck Forum | 5 | 03-23-2006 08:58 AM |
| chevy s10 fuel injector problem... | rrodriguez190 | Chevy Truck Forum | 8 | 10-30-2005 12:23 AM |
