Old 03-06-2007, 06:26 PM   #1
dilli is on a distinguished road
Please Fix My Tahoe!!!
Help guys!!!! I am a female driving old 1979 and 1989 Blazers.....finally saved enough $ to buy a 1999 Tahoe Sport with a 5.7 [ I think :}] 70,000 miles, real black beauty.....thought I was in heaven!! Guess again! Here's the details........starts out when I would go up a big hill [ about a mile long] I would get 3/4 of the way up and it would start missing/shuddering. Service engine light came on and started blinking.........code stored said 02censors and this time it said random misfire on cylinder 4. Have replaced 4 02censors, plugs,wires,dist. cap. Drove it 2 weeks.......today I go to go up the same big hill and here we go again.....doesn't feel like a miss....feels like it is shuddering/shimming....service engine light flashes a couple times...pull off the road....light stays on but doesn't flash....drive 30 miles and all is fine. Head back home and it does the same thing on a hill. Take off again tonight and it runs fine about 25 miles......light goes off.......3 miles later on a small incline it starts shuddering again..light flashin the whole works! I have close to a grand in the repairs already and it's still not fixed....every mechanic has their own opinion.........please tell me yours!!!! Thanks guys!!
dilli is offline   Reply With Quote
Old 03-06-2007, 08:01 PM   #2
dstrick32 is on a distinguished road
Just becauseyou get a O2 sensor code doesn't mean the sensor is bad. Could be many things that cause the engine to run rich or lean, wiring circuit or etc. Can you be more specific and state the TDC's?
95 Ford F-150XL 5.0 Automatic
92 Chevy Silverado 5.7 Automatic
94 Toyota Ex-Cab 4X4 3.0 Automatic
dstrick32 is offline   Reply With Quote
Old 03-06-2007, 09:33 PM   #3
dstrick..nice to meet you! You mean to tell me I might not have needed the 02 censors at all?? This just keeps getting better......... I will try to get any info needed to fix this.....but I need to know what you mean by state the TDCS?? What is a TDC? I have no clue......Thanks!
Old 03-06-2007, 09:53 PM   #4
Moderator
It should be DTC (Diagnostic Trouble Codes)
Old 03-07-2007, 06:48 AM   #5
daman's Avatar
daman is on a distinguished road
Have your truck scanned again for codes and post them here, you said
you replaced the dist. cap,what about the rotor?,thats with the cap but
under it.
1999 1500 Z71 4x4 5.7 Vortec 3:73 posi LS Extended Cab Shortbed
daman is offline   Reply With Quote
Old 03-07-2007, 10:21 PM   #6
chevyguy's Avatar
Sounds like a bad coil to me. It will drop a cylinder and usually cause a check engine light. Excessive unburnt fuel can cause the O2 sensor to read rich.
Old 03-08-2007, 09:44 AM   #7
436'd skylark is just really nice436'd skylark is just really nice436'd skylark is just really nice436'd skylark is just really nice436'd skylark is just really nice
Change the fuel filter and check the fuel pressure. my guess is its working to get up the hill, and running out of fuel pressure. The engine runs lean, and falls on it's face. hence the stumbling/sputtering. I'd start there. The filter is like 5 bucks, as long as the lines are decent, it should be an easy job.
Joe
89 K2500 Chevy, Wee-Oh-five
285K miles, completly rebuilt
needs a motor, bad
152 ci, dana everything else
436'd skylark is online now   Reply With Quote
Old 03-08-2007, 11:33 AM   #8
I would also look into the possibility of the fuel filter being clogged or something.
By the way, how much gas is in your tank when you are on the hill?
Do you have any gas smell after it sputters?
Have you checked for vacuum leaks?
Is it Fuel Injected or Throtle Body Injected?
I WOULD CONSIDER CHANGING THE WATER TEMPERATURE SENDING UNIT. IT IS CHEAP TO FIX AND WHEN IT IS BAD, IT CAN MAKE YOUR CAR RUN LIKE ****. MY 95 S10 DID THE SAME THING AND I NEVER IMAGINED IT WOULD BE A WATER TEMP SENDING UNIT.
Old 03-08-2007, 11:34 AM   #9
How would a coil drop a cylinder if it is connected to the center of the distributor cap?
Or do these things have coli packs?
Old 03-08-2007, 11:35 AM   #10
Moderator
its a 99, its going to be multiport.
2000 Chevy Tahoe smokejumper0902 GMC Truck Forum 0 07-28-2006 06:45 AM
Current Draw - 1998 Chevy Tahoe bugnutz Chevy Truck Forum 6 05-22-2006 08:42 AM
1997 chevy tahoe gage light problem bajaboy Chevy Truck Forum 5 03-23-2006 08:58 AM
99 chevy tahoe gortiz Chevy Truck Forum 0 02-03-2006 08:40 PM
QCTimes.Com: Top Jobs: CHEVY '99 Tahoe LT 4x4 (Quad-City Times) trucknews Truck News (headlines) 0 09-10-2005 09:30 AM
