Old 03-06-2007, 10:21 PM   #1
benjiboy is on a distinguished road
1990 TBI Silverado No fuel or spark!?
Had the truck since new always been extremely dependable. Two days ago go to start it up in the morning, it runs for 10 seconds then dies. No sputtering just dies. Now it won't start and I'm pretty sure it isn't getting any spark and looks like no fuel either.
I'm pretty decent with cars and had a TBI Camaro but mainly deal with speed density stuff now and need some ideas to start.
I've ruled out fuel pump and fuel filter. I pulled the codes and got nothing but this was after I unhooked the battery to see if this was just some fluke electronic problem; will try to start it again and then pull them again tomorrow. Fuses are all good.
Is this a relay or module somewhere?
Thanks in advance all
-Ben
benjiboy is offline   Reply With Quote
Old 03-07-2007, 05:59 AM   #2
Moderator
do you know for a fact that it is not getting any spark and fuel?? if both of them went out at the same time, it might mean something is wrong with the computer.
Old 03-07-2007, 12:41 PM   #3
Its not getting any spark checked with two inline spark checkers and I can't see any fuel being intorduced into the motor when trying to start and giving it gas.
I was thinking ECM is a defenite possibility but didn't know if there was anything much easier to check out first.
thanks!
Old 03-07-2007, 04:21 PM   #4
Moderator
i think that would be a near dead giveaway. cant think anything else that would kill spark and gas.
Old 03-07-2007, 06:55 PM   #5
I might just have to go to the boneyard and grab one this weekend.
Addressing the two seperatly what would need to be checked...
FUEL:
Pump
Throttle Body
Fuel Filter
SPARK:
Dizzy
Coil
Anything else I can get on the list...relays are a big one here I don't know much about on this truck.
Old 03-08-2007, 06:05 AM   #6
Moderator
lots to check. fuel wise, everything you said plus your injectors. i have seen one not fuel because the wire was hanging off the injector. plugged it up and started fueling again. also fuel pressure. TBI takes a higher pressure than a naturally aspirated engine. as for spark, check the coil wire. i have seen these break down too. spent two days trying to find the problem when i picked it up and it came apart.
i am assuming that you have power to everything inside your truck??
Old 03-08-2007, 08:53 AM   #7
yea everythings got power
Old 03-08-2007, 09:33 AM   #8
436'd skylark is just really nice436'd skylark is just really nice436'd skylark is just really nice436'd skylark is just really nice436'd skylark is just really nice
The problem is not the computer. The ignition system used on those trucks is very primative. The computer can be unplugged, missing or whatever and the truck will still spark, just no advance. If you lost both fuel and spark the problem is either the pick-up coil or the module for sure. Assuming of course the harness is in good shape- power to the coil, and the two and 4 pin connector at the module are good, as in not green or broken. I'd pull the distributor and replace both. In order to replace the pick up coil, the distributor shaft must be removed from the housing. its a fairly easy job just make sure to set the timing afterwards. If you want to make it real simple, just replace the module. Likely it will fix your truck, but if not dig into the distributor and replace the pick-up coil. That is really common on those. WooHoo, first post. Joe
436'd skylark is online now   Reply With Quote
Old 03-08-2007, 01:28 PM   #9
thanks for the reply. you are referring to the HEI control module in the dizzy cap right? this is a small cap dizzy with the remote mount coil.
Old 03-08-2007, 01:42 PM   #10
yeah I'm refering to the module in the cap. Start there.
Joe
89 K2500 Chevy, Wee-Oh-five
285K miles, completly rebuilt
needs a motor, bad
152 ci, dana everything else
Original Owner 1990 Silverado New to the forums benjiboy Introductions 2 03-07-2007 06:58 AM
1990 Silverado K1500 Z71 350 TBI smokensteve Chevy Truck Forum 11 01-05-2007 05:16 PM
85 silverado fuel pump mystery mntman Chevy Truck Forum 2 01-19-2006 08:35 AM
P/O 1990 Chevrolet Silverado stepside Volare80 Chevy Truck Forum 0 03-04-2005 06:59 AM
1990 Chevy Silverado Water Pump RICK Chevy Truck Forum 3 02-11-2005 07:20 AM
