Old 03-07-2007, 05:36 PM   #1
PickUpGirl787's Avatar
PickUpGirl787 is on a distinguished road
Talking clearance lights or no?
Ok so I have an ugly truck, I'll admit it, but I want to make it look a little cooler if I can, so who thinks that clearance lights would look good on my Chevy 1988 1500?? and is there any way to make the front end the same height as the back so that the truck sits level?? or is this going to involve lift blocks??
Ashley
My first truck was a 1988 Chevy 1500 with the 305
My new truck is a 1997 GMC 1500 with the 350
PickUpGirl787 is offline   Reply With Quote
Old 03-07-2007, 10:13 PM   #2
chevyguy's Avatar
NEVER under any circumstance install lift blocks in the front end of a vehicle. i assume your truck is a 4wd?
USMC 92-96 USCG 98 to present
Old 03-07-2007, 10:43 PM   #3
I say no lights. I just do not like them.
As far as the leveling kit goes, if that truck is 4x4, then I believe you have torsion bars. Blocks should never be an option for the front EVER. ( the side loads against the front spring due to the front tires turning back and forth while steering will cause the blocks to eventually fall out.) Wasn't the 87 the last of the leaf sprung front end? If it still had leaf springs, then a new spring pack is only a couple of hundred bucks for new ones. If it is a torsion bar front end, then a leveling kit, like a pork chop (torsion bar re-indexing key) style will work. If it is 2wd, then you will have to purchase a new spring(s) to lift the front to the desired heigth. Be carefull with the upper ball joint here, increased lift with the stock upper a- arm really binds the ball joint. Sometimes hard to align if you lift too far.
Old 03-08-2007, 08:00 AM   #4
k thanks
Ashley
Old 03-08-2007, 08:32 PM   #5
chevyguy's Avatar
1988 1500 was IFS 4wd and IFS 2wd. No front leafs to attach blocks to. i was just making a point earlier. Anyhow assuming its a 4wd,just cranking the torsion bar bolt a little wont hurt anything and it will lift the front a bit. Dont go crazy and crank the heck out of them, Thats a great way to really mess up front end angles and make it ride trerrible.
Old 03-09-2007, 05:56 AM   #6
Its a 2wd truck, I know I told you it sucks so would it still have torsion bars that I can have adjusted? I have actually seen how to do the whole torsion bar thing, but I have someone that will do it for me, so I wont be the one messing anything up!!
Ashley
Old 03-09-2007, 07:52 AM   #7
03chevy's Avatar
no you don't have torsion bars just springs
Old 03-09-2007, 08:23 AM   #8
Coil springs that is
Old 03-09-2007, 12:38 PM   #9
darn that means money !!
Ashley
Old 03-09-2007, 01:32 PM   #10
Just springs shouldnt be too expensive
1997 GMC Jimmy Courtesy lights & Blower Moter georgetown GMC Truck Forum 0 01-28-2007 03:21 PM
No dash or tail lights - ? Donut John Introductions 3 01-05-2007 11:00 PM
Lights blinking on '97 F-150, low battery?? okiefarmer Ford Truck Forum 9 12-01-2006 11:04 AM
help! no rear lights on suburban!! tdolbow Chevy Truck Forum 9 11-03-2006 02:50 PM
Turn signal cancels daytime lights TonyK GMC Truck Forum 7 10-24-2006 06:33 AM
