| axle loose on 4wd I got this 4wd cheyenne for a song hoping the horrible growling/grinding sound was simply a wheel bearing. WHen I jacked it up I come to see that the axle from the transfer case to the driver's side hub moves in and out four inches which does not seem correct. I would have started to tear into it but did not have a socket large enough to remove the nut that on 2wd holds the bearing in place. How tough is this job? Approx cost? HOurs to do myself. Size of socket? Did a search without result. Can't belive this is the only rig that has had this fail so I am wondering if everyone just took it to a shop. |
| Sounds like your missing the c clip. Take both side apart and compare what you remove. My bet is that you will find it has been assembled without the c clip. Wont make it grind, but should limit travel. My bet on the grind is still the bearing.
| CV axle help | HIUPCHEVY11 | Chevy Truck Forum | 9 | 03-03-2007 06:43 PM |
| 96 f250 axle swap | nickm79 | Ford Truck Forum | 0 | 12-16-2006 10:55 PM |
| replacing axle bearing | crazyhorse357 | Chevy Truck Forum | 4 | 10-21-2006 11:10 AM |
| American Axle & Manufacturing Announces Launch of ****** H3 Program (The Auto Channel) | trucknews | Truck News (headlines) | 0 | 04-29-2005 11:30 AM |
| Truck Axle From OKC Bombing Gets New Home Axle, Other Items Go On Display At Museum (40/29 KHBS/KHOG) | trucknews | Truck News (headlines) | 0 | 04-10-2005 05:30 PM |
