Old 03-12-2007, 02:51 AM   #1
greasemonkeys69 is on a distinguished road
Unhappy 94 z-71 wont idle
hey ya'll newbe here my husband and i just tranny in truck and changed plugs, oil, wires, oil pump, and filters. when we first crunk her up she ran great then she started running bad and eventually died. crunk back up but had to keep gas to her and smokes white smoke really bad which we have a loose manifold also. but then i crunk her up about 2 hours later and she'll crank and run with no gas now but idles like ****!! and we checked the plugs and they had black like soot on them please help us figure this out. i'm thinking either map sensor or control module THANKS!!!!
greasemonkeys69 is offline   Reply With Quote
Old 03-12-2007, 07:12 PM   #2
junior3382's Avatar
It could be a bad map sensor, but i would check the cat. You may not be venting all the exhaust if you have soot on the plugs. Check the cat/exhaust for restrictions.
Parts have been found, tools are collecting, tensions are rising, the weather is changing...look out.... the SAS is comming!
Old 03-12-2007, 10:09 PM   #3
it's running good now but now tranny doesn't have reverse, starts in all gears, all the gears are scrambled. but drives and shifts okay but motor seems to bog down at times
Old 03-13-2007, 10:23 PM   #4
chevyguy's Avatar
If the gear selector isnt adjusted properly you wont have reverse or park. Just need to disconnect the shift linkage below the truck and manually put the trans in park, put the shifter in park and reattach the linkage.
1987 Silverado 350 TBI Auto., hard start, won't idle 87Silverado Chevy Truck Forum 8 07-08-2007 07:20 PM
Idle and Tranny problems Frogestil Ford Truck Forum 0 12-07-2006 05:40 PM
Idle speed in 22re mochester Toyota Truck Forum 3 06-11-2006 10:52 PM
73 k-10 idle problems havoc1336 Chevy Truck Forum 0 12-13-2005 11:27 AM
99 Suburban Idle Problem Myles Chevy Truck Forum 3 08-05-2005 10:24 PM
