Old 03-12-2007, 10:07 AM   #1
dusted800 is on a distinguished road
engine surging?
91 C1500 with 305. Engine will run fine but at idle it will start to die a little and then catch it self and rev up a little. It almost sounds like an old carbuerated engine that loads up a little. It will continue to do this as long as it is idling. There is no engine light on. I have checked for codes and there is none. Can anyone give me a place to start or a sensor that is possibly doing this. thanx. wnk.
dusted800 is offline   Reply With Quote
Old 03-12-2007, 10:16 AM   #2
junior3382's Avatar
the Throttle position sensor (TPS) or map sensors.
Parts have been found, tools are collecting, tensions are rising, the weather is changing...look out.... the SAS is comming!
Old 03-12-2007, 03:50 PM   #3
Also meant to say that when you start it up for the first time it doesn't start the surging for approx 3-5 minutes. When it starts, it is on high idle and will run for a few minutes just fine, then the idle comes down to normal and it will run a few more minutes and then it will start surging. thanx. wnk.
Old 03-12-2007, 04:25 PM   #4
junior3382's Avatar
Sounds like it runs fine until it warms up. When it warms up, the air fuel mixture is off. I would look at the o2 sensor or even the egr valve...
76 Chevy 454 - massive oil leak in rear of engine MrDavidOgle Chevy Truck Forum 19 10-07-2007 01:46 PM
How best to remove 1972 Chevy 4x4 engine? rstricklin Chevy Truck Forum 3 08-27-2006 05:36 AM
WTB 3.0 v6 for a 92runner jvmin Truck Classifieds 15 07-18-2006 06:57 AM
Carb to TBI engine swap klink70 Chevy Truck Forum 5 02-17-2006 10:54 AM
Engine Identified! Anyone know specs? klink70 Chevy Truck Forum 1 01-30-2006 10:07 PM
