| Full Member Join Date: Mar 2007 Location: SENATOBIA MS
| no reverse!!! truck is purring now but it has no reverse, and it will start in all gears, and it jumps forward, but will shift while driving but motor seems to bog down at times HELP!!!!!! |
| the starting in gear is becuse your neutral safety switch is bypassed. The no reverse tells me you probally have a bad transmission. the bogging down, we will need more info.
| hey we took it to someone who knows a thing about tranny's and he got it pretty much fixed. reverse was just seized up from sitting for so long and the gear shifter had a little too much play in it. but its still a little sluggish or weak in drive. we are driving the **** out of it hoping the valves may just be stuck and also using lucas. thanks
__________________ |
| Full Member Join Date: Aug 2006
| I have a lot of play in my shift lever. how do you fix that? |
| took a rachet and tightened up under hood on steering column
| they tightened the linkage. I talked about this on your other post about this same issue.
| 2004 Chevy Recalls | ChevYvehc | Chevy Truck Forum | 3 | 10-26-2006 09:19 PM |
| Reverse light do not work? | seventhson | Chevy Truck Forum | 5 | 09-18-2006 03:32 PM |
| 1991 manule trani prob will not go in reverse | I3 U T L 3 R | Chevy Truck Forum | 2 | 09-28-2005 04:25 AM |
