Old 03-13-2007, 03:23 PM   #1
chandler is on a distinguished road
98 tahoe fouling #3 and #5 plugs
hello to all i am new here .my 98 tahoe has all of the sudden started consuming oil and fouling plugs # 3 and #5 it has a 5.7 vortec . engine runs great untill it fouls plugs no smoking or rough idling . i did a compression test all cylinders are between 200 and 210 . did some more troubleshooting today and noticed my pcv valve wich i put in 6 months ago is clean as new this is where i noticed something really strange when i pulled the pcv valve out of valve cover while engine was running engine started to die then idled rough plugged the end of it with my thumb still idled rough . i put it back in valve cover then noticed engine was building up a vacum at the oil fill tube then when i took my hand off of the fill tube engine wanted to die agian the idled rough
heve never encounterd a problem like this before . could i have a leak in the plastic intake or at the base of the intake . any help would be greatly appreciated . also the check engine light does not come on and there are no trouble codes
baffled in maryland
steve
chandler is offline   Reply With Quote
Old 03-13-2007, 07:32 PM   #2
junior3382's Avatar
two questions, How many miles does the engine have? Does it have a timming chain or belt?
Old 03-14-2007, 02:06 PM   #3
truck has 98 thousand miles it has a timimg chain smallblock V8 gen 1. just to test i drove truck with the oil fill cap off it has a slight hesitation now at takeoff but has a lot more power and gets way better gas milage. engine has no knocks or noises in the valve train and runs 55 lbs of oil pressure after warmup
Old 03-15-2007, 07:23 PM   #4
Browndog350's Avatar
Browndog350 is on a distinguished road
Sounds like an internal intake manifold leak. Running with oil filler cap off might be allowing cylinders to pull enough crankcase gas/air mixture to actually run O.K. This also explains the oil consumption and plug fouling. Vacuum created with hand on oil fill tube is further evidence especially when engine wants to die when you pull your hand off. Hope this input helps with getting that Chevy running good again.
Browndog350 is offline   Reply With Quote
Old 03-17-2007, 10:08 PM   #5
hey browndog just got finished putting engine back together it was the manifold gaskets engine runs great now thanks for reply
Rough idle and Stutter on acceleration 2003 Tahoe 5.3 Vortec jnettrecker Chevy Truck Forum 17 12-16-2006 08:30 AM
2000 Chevy Tahoe smokejumper0902 GMC Truck Forum 0 07-28-2006 06:45 AM
Current Draw - 1998 Chevy Tahoe bugnutz Chevy Truck Forum 6 05-22-2006 08:42 AM
1997 chevy tahoe gage light problem bajaboy Chevy Truck Forum 5 03-23-2006 08:58 AM
97 Tahoe 5.7 liter starting problem StevesTahoe Chevy Truck Forum 0 06-07-2005 07:11 PM
