Old 03-15-2007, 05:01 PM   #1
claytonfrnk's Avatar
claytonfrnk is on a distinguished road
Question Temp gauge Help
Hey guys i am doing a motor swap in my 85 K10. THe 305 is out and a 350 is going in. I have a problem. The Temp gauge plug (the part that screws into your head) doesn't fit in the 350 head. I have a reman engine and the heads are from a 1968-1976 350. Where do i find a plug that screws into the head. This sounds dumb but i have called autozone and advanve auto they can't find one. I don't just want to plug it cause i want the gauge to work. thanks
claytonfrnk is offline   Reply With Quote
Old 03-16-2007, 05:28 AM   #2
just use the 305 heads, it'll give you higher compression though.
i'd rather be hunting
Old 03-16-2007, 07:20 AM   #3
You can purchase an reducer if the threaded hole is bigger than the sending unit. Your local auto parts does cary it, even if they do not think they do. Most of those clowns usually start with "what year is the vehicle" as they type the info on the keyboard, can only read the puter screen, and have little to no knowledge of real world applications. Look inside of the package of an aftermarket temp gauge. All of these come with a veriety of threaded adapters. You will see waht you need.
If the adapter can't be located, then you still have the option to install the sending unit in the intake. The intake will accept the larger sending unit, and the head will have to be plugged. This plug is easy to find. This can be found at your local home improvement store.
This isian easy problem to solve, you just have to locate the components to do so. Good luck...
fuel gauge? 396chevy Chevy Truck Forum 5 01-15-2008 11:04 AM
Gauge Readings Bob Bradford Dodge Truck Forum 1 02-01-2007 09:37 AM
Fuel gauge doesn't work bigbassmann Dodge Truck Forum 4 01-31-2007 07:16 PM
water temperture gauge question crazyhorse357 Chevy Truck Forum 6 08-07-2006 08:41 PM
check engine/gas gauge r5-7hemi Dodge Truck Forum 1 06-14-2006 10:57 AM
