Old 03-21-2007, 12:10 PM   #1
C30 Dooley's Avatar
C30 Dooley is on a distinguished road
Non-functioning temp gauge
I wonder if someone can point me in the general direction of the temp sending unit for my '85 Silverado C30. Engine is a 350. The gauge had been reading very low for quite a while. I recently put a new radiator, tstat, & heater core in her, and now it seems the gauge doesn't move at all. The rest of the cluster works fine, so I figure the sending unit is bad.
Thanks!
C30 Dooley is offline   Reply With Quote
Old 03-21-2007, 03:11 PM   #2
Moderator
bradrhale is a splendid one to beholdbradrhale is a splendid one to beholdbradrhale is a splendid one to beholdbradrhale is a splendid one to beholdbradrhale is a splendid one to beholdbradrhale is a splendid one to beholdbradrhale is a splendid one to beholdbradrhale is a splendid one to behold
drivers side head almost halfway back. i had to replace mine but i dont believe that you can replace just that unit. it is not a sending unit like the oil is where you disconnect the wire and go. i ended up going with an aftermarket guage. partly because i am too lazy to tear into the panel and replace the factory unit from the junkyard.
Old 03-21-2007, 07:27 PM   #3
claytonfrnk's Avatar
claytonfrnk is on a distinguished road
I would buy a 3 gauge pod and be done with all the factory gauges. So you don't have to trouble shoot faulty gauges for a while but thats just me. If your under the hood once mite as well do em all.
claytonfrnk is offline   Reply With Quote
Old 03-22-2007, 11:41 AM   #4
Is it the same as the coolant sending unit?
Mine is in the front near the neck where the thermostat is located. BTW, I have a 5.0 enigine.
Old 03-23-2007, 06:53 AM   #5
Moderator
yes, but he has the 5.7.
Old 03-24-2007, 11:16 AM   #6
C30 Dooley's Avatar
Found it! It sits between the frontmost two spark plugs, has a green wire going to it. I cleaned up the connection and now I'm getting it to read about where it always was, which is on the cold side of the first graduation on the gauge. Now I don't know whether to try to find the sender, or just let it ride.
Old 03-24-2007, 08:15 PM   #7
C30 Dooley's Avatar
To clarify, I mean I don't know whether to try to find a new replacement sending unit or just leave well enough alone.
Old 03-24-2007, 08:31 PM   #8
Moderator
if it is working like it is supposed to and goes up when it gets up to temp and then back down when the t-stat kicks in, i wouldnt worry about it. i changed mine when it wouldnt come off zero in the middle of summer with the ac on in downtown traffic.
Temp gauge Help claytonfrnk Chevy Truck Forum 2 03-16-2007 07:20 AM
Gauge Readings Bob Bradford Dodge Truck Forum 1 02-01-2007 09:37 AM
Fuel gauge doesn't work bigbassmann Dodge Truck Forum 4 01-31-2007 07:16 PM
fuel level gauge 396chevy Chevy Truck Forum 1 08-12-2006 08:02 PM
water temperture gauge question crazyhorse357 Chevy Truck Forum 6 08-07-2006 08:41 PM
