Old 03-22-2007, 06:46 AM   #1
Exhaust
I have a 1996 Silverado 5.0 and I think it needs a Catalytic Converter.
The mechanic did a code diagnostics.
The price for the part that I've been quoted is $275.00 + labor. Is this reasonable?
Do I have any other options?
Old 03-22-2007, 07:13 AM   #2
03chevy's Avatar
one of the tell tell sings of a cat going bad is when you have the truck up to normal running temp look at the cat best when it's dark outside to see if it is glowing red that's the best way to see. but i would call around diff muffler shops bc you will get diff prices
Old 03-22-2007, 08:19 AM   #3
PickUpGirl787's Avatar
PickUpGirl787 is on a distinguished road
eh just take it off!! Kidding but it would be fun to be the loudest one on the road for a while dodging the cops
Ashley
My first truck was a 1988 Chevy 1500 with the 305
My new truck is a 1997 GMC 1500 with the 350
PickUpGirl787 is offline   Reply With Quote
Old 03-22-2007, 08:28 AM   #4
most aftermarket high flow units cost about half of that, and a muffler shop can install it for considerably less.
The glowing cat only works after say a run on the freeway, and exhaust temps are high. A cat will not start glowing at idle. Engine will not create enough heat at idle to make it glow. Also it will only glow if the cat is plugged. A cat that has broken pieces inside that may not restrict flow, will not impede flow enough to cause a super high heat symptom.
Old 03-22-2007, 11:36 AM   #5
I'd take it off it I could..........
I dont want loud though.....
Old 03-22-2007, 11:38 AM   #6
I've heard about the red glowing deal before. I didnt think it worked in every case.
Old 03-22-2007, 11:38 AM   #7
I will give it a shot tonight and see what happens.......
Old 03-23-2007, 04:14 AM   #8
Bonnor is on a distinguished road
i thought 95 was teh last year you could just cut the cats off...96 has 4 o2 sensors so you can't just cut it off unless u get teh o2 simulators..or am i thinkin wrong here?
Bonnor is offline   Reply With Quote
Old 03-25-2007, 03:24 AM   #9
yes you are right, the cat is part of the exhaust cross over. there are o2 sensors at each end of the cross over, and i belive one befroe and after the cat. the price sounds about right, i found out the hard way, stupid sawsall.
i'd rather be hunting
Old 03-25-2007, 09:12 AM   #10
A little food for thought. I run a 6.0L chev from an 01 silveerado with no cats, and all 4 original O2 sensors, with no check engine lights.
I also have a G.M. performance parts LS7 427 ci sbc, and it too runs without the use of cats, and uses a 4, O2 sensor system, no lights, or codes......
4x4 & Exhaust Question 92BlueZ71 Chevy Truck Forum 2 10-07-2007 01:38 PM
exhaust j walters Chevy Truck Forum 3 08-02-2007 01:48 AM
"No-Drone" exhaust for Duramax Russ Weaver Chevy Truck Forum 2 02-16-2007 01:43 PM
Stumped on exhaust 1995C3500 Chevy Truck Forum 4 07-28-2006 04:05 AM
99 suburban exhaust 72'CaminoKid Chevy Truck Forum 5 08-17-2005 06:31 AM
