Old 03-25-2007, 03:04 PM   #1
PickUpGirl787's Avatar
PickUpGirl787 is on a distinguished road
Exclamation tailgate
has anyone had a problem with the late 1980's early 1990's chevy 1500 tailgates? On the right side the latch will move in and out, but on the left it wont come out all the way, i can get it to come out pretty far with pliars but then as soon as you pull the handle to open it, it goes in and stays in. Any ideas?
Ashley
My first truck was a 1988 Chevy 1500 with the 305
My new truck is a 1997 GMC 1500 with the 350
PickUpGirl787 is offline   Reply With Quote
Old 03-25-2007, 03:09 PM   #2
junior3382's Avatar
actually, i have seen this several times before, I have found that usaully it needs some lubrication. And not just a spray on WD-40 but take it apart, clean the little piston and lube it with a good grease. WD-40 tends to dry it out and make it worse.
Old 03-25-2007, 03:34 PM   #3
Small plastic retaining clips that hold the latch to the release arms are broken. Common problem, and it happens to all makes. They sell for less than a couple of bucks, and only take a moment to install.
Old 03-25-2007, 03:39 PM   #4
ikos10's Avatar
ikos10 is a jewel in the roughikos10 is a jewel in the roughikos10 is a jewel in the roughikos10 is a jewel in the rough
these guys are both right, I would try both, besides lubrication never hurts.... and broken parts should always be replaced....
ikos10 is offline   Reply With Quote
Old 03-25-2007, 03:43 PM   #5
thanks ill try it, I have to buy a new hex tool though the first one broke because the bolts were on there too tight
Ashley
Old 03-25-2007, 09:10 PM   #6
the tailgate on my 97 would never latch shut tight, if you hit a good bump it would fall open. i ended up taking the handle out and drilling out the rivet that held the handle together. i replaced the rivet with a short bolt and lock nut, with the lock nut you could keep the parts loose instead of pressed to each other like the rivet. this solved my problem, not sure if it will help you.
i'd rather be hunting
Tailgate load capacity stelmadl Chevy Truck Forum 2 01-23-2007 10:46 AM
Tailgate Cargo Box - the Hottest New Truck/SUV and RV Accessory (Primezone via Yahoo! UK & Ireland Finance) trucknews Truck News (headlines) 0 11-30-2004 11:30 AM
