Closed Thread Chevy Truck Forum - Chevrolet / Chevy trucks and their accessories forum.
Old 03-26-2007, 11:49 AM   #1
rkrizan is on a distinguished road
Exclamation 1988 Silverado k1500 z71 - runs great, for a few minutes.
I have a problem with my pickup. It has a relatively fresh motor, with only 30,000 on a crate engine (350CI/TBI). It ran great for about 2 years of use. The other day, I started it up to do some hauling and I left it to idle for about 5 minutes before I moved it, which I normally do, however, it started idling higher and higher and the check engine light came on. I figured the automatic choke was stuck or something, and at this point the engine was at proper operating temperature anyhow so I tapped the throttle to bring it back down. The truck starting choking and it died, and would not restart. It wouldn't kick at all, as if it was starving for fuel. So I checked the plugs, they had a little carbon on them, so I replaced them, along with the cap, router and wires. Of course by this time the engine was cool again, so it fired right up. I again let it sit for a few minutes, and it did the same thing. I let it cool for a couple hours, pulled the oxygen sensor, cleaned it off a bit, changed the air filter, checked the map sensor plug, and even tested the map sensor, all seemed fine.
This time, when the engine was cool, I started it up, and immediately took it out on the road and opened her out, thinking maybe she needed her throat cleared, ran great, until it got to proper temp again. Got it back to the yard, she died, refused to start. I'm kind of lost, as I've tried tracing down any electrical problems, replaced several parts, etc. Any of you know what I might be missing? I know chevy engines like the back of my hand, so any help would be much appreciated. The only thing I haven't checked is the computer, however from what I'm told once a computer goes, it goes.
I've just recently replaced the fuel filter, and pump as well.
Thanks
rkrizan is offline
Old 10-28-2009, 01:08 AM   #2
chadwickthomas is on a distinguished road
it SOUNDS LIKE YOUR IGNITION MODULE IS BREAKING DOWN OR THE PICK UP COIL IN YOUR DISTRIBUTOR IS GOING OUT BUT ITS PROBABLY THE MODULE SINCE THE PICK UP WILL SET A CODE AND THE MODULE WILL NOT
chadwickthomas is offline
Old 10-28-2009, 03:19 AM   #3
was a code set? a stickey egr will do that!
leolkfrm is offline
Old 10-28-2009, 01:51 PM   #4
and leo gets got again.
bradrhale is offline
Old 10-28-2009, 02:04 PM   #5
Wyley87's Avatar
Wyley87 is a splendid one to beholdWyley87 is a splendid one to beholdWyley87 is a splendid one to beholdWyley87 is a splendid one to beholdWyley87 is a splendid one to beholdWyley87 is a splendid one to beholdWyley87 is a splendid one to behold
shouldnt we close threads that have had no activity in over a year to prevent this sort of thing
96 GMC C1500 305 2WD
K&N FIPK C.A.I.
Rebuilt Motor and Trans
Mobil 1 15w50/Mobil 1 Filter
05 Nissan Xterra 4.0 V6
Royal Purple 5w30/Mobil 1 Filter
Cost money to go fast...How fast do you wanna go?
Wyley87 is offline
Closed Thread
1988 Silverado k1500 - runs great, for a few minutes. rkrizan Chevy Truck Forum 14 03-28-2007 05:20 PM
1990 Silverado K1500 Z71 350 TBI smokensteve Chevy Truck Forum 11 01-05-2007 04:16 PM
94 K1500 Runs Rough When Cold tdyer Chevy Truck Forum 0 04-07-2006 05:32 PM
1988 chevy k1500 hampton Chevy Truck Forum 3 09-29-2005 08:11 AM
1988 K1500 Cooling Problems HELP boxcarcop Chevy Truck Forum 3 08-09-2005 11:43 AM
