Old 03-26-2007, 01:37 PM   #1
markbark22 is on a distinguished road
Failed Smog
I have a whipple supercharger on a 2000 silverado and i failed the test because of the computer not being able to be read. Any recommendations? thanks
markbark22 is offline   Reply With Quote
Old 03-26-2007, 02:26 PM   #2
ikos10's Avatar
ikos10 is a jewel in the roughikos10 is a jewel in the roughikos10 is a jewel in the roughikos10 is a jewel in the rough
At any aftermarket performance shop, you can purchase a bypass regulator for your o2, and air mixture sensors wich should allow it read right from your computer.... I wouldn't nescesarily recomend this, but it has worked for a few people I know.
ikos10 is offline   Reply With Quote
Old 03-26-2007, 02:36 PM   #3
junior3382's Avatar
Yeah that will work, but you need to make sure you get them tuned so that you don't cause the mixture to be too lean. but if you go that route, the guys at the performance shop should be able to help you there too.
Old 03-26-2007, 02:43 PM   #4
Ok but the only problem im really having is that it has worked before by just re programming it to the trucks original specs, what will the bypass do and doesnt the programmer do that in itself
Old 03-26-2007, 03:07 PM   #5
ikos10's Avatar
Originally Posted by markbark22 View Post
Ok but the only problem im really having is that it has worked before by just re programming it to the trucks original specs, what will the bypass do and doesnt the programmer do that in itself?
Yes and no. By in stalling the bypass, the o2 sensors read the exhaust as fine, and air mixture will help, so when you get the lovely polution test that we now need, because these sensors are tuned to the supercharger, then the exhaust... thru the computer... will read clan. Now when you reprogrammed the brain for the supercharger, that changed the timming settings and performance for air intake, however, your other sensors are still operating under original peramiters. Does that make sense? It is a cheap part, in comparison, and I know a few people who used it and it works. but for a complete description, check with the guys at the performance shop, since they will have to order the right one for your application anyways, i am sure they can explain it better....
Old 03-26-2007, 05:29 PM   #6
yeah ok, i will definitley look into that today thanks again
Old 03-26-2007, 07:21 PM   #7
As long as we are talking about cheating the emissions test, I use nitrous oxide to do it. I spray through a jet I modified with only a .009 orifice. Since the test is measured in PPM, the scale is thrown off by the introduction of additional oxygen, thus a clean emissions passing 521 CI big block ford on race gas. Should hear that roller cam cracking those valves open and closed, with that idle we all know, and love, and watching those guys doing the test shrug their shoulders when it passes,,,,priceless!
You can trick the machine (sniffer) pretty easily by introducing more oxygen into the exhaust system, not to tricky, and easy to conceal.
Just thought I would share...he, he....
Old 03-26-2007, 08:43 PM   #8
72'CaminoKid's Avatar
lol. i can picture the look on their faces
99 suburban xlt
96 silverado
91 wrangler (my baby )
Old 03-27-2007, 06:43 AM   #9
glad you pointed that out. i have never thought about that until you said something. WATCH OUT!!
Old 03-27-2007, 08:22 PM   #10
junior3382's Avatar
okay, thats funny, but does it work? and are there any lasting effects? i mean can it damage anything?
Cali Smog Stroker philo GMC Truck Forum 2 01-24-2007 05:08 PM
1994 Chevy S10 Failed emission test mamabear Chevy Truck Forum 6 10-11-2006 03:11 PM
sneaky used car salesmen and smog mochester Toyota Truck Forum 4 06-05-2006 02:00 AM
