| Senior Member Join Date: Dec 2006 Location: Illinois
| I have a question... Is there anyway to manually pull the codes on a 1988 Chevy 1500? I don't have a code reader for my engine (305) and I keep having the CHECK GAUGES light come on and off while I am driving. Any help would be great
__________________ Ashley My first truck was a 1988 Chevy 1500 with the 305 My new truck is a 1997 GMC 1500 with the 350 |
| The check guages light comes on only when one of the guages in the red. either low oil pressure, or high temp. The Check engine light is a separate deal. When does the light flash? Try to glance down when that happens and check the guages. Like a bonehead I let my truck run low on oil and it would flash when I stopped hard or went around a turn. A couple of quarts later I was all good. I have almost the same truck as you.
| Full Member Join Date: Jan 2006 Location: Southeast Iowa
| I can't remember which holes to use but under teh steering column there's a plug and if you put in a jump wire the service engine light will blink a number of times corresponding with the certian code. then just look it up in a book. |
| It's the two upper right terminals.
__________________ '85 Oldsmobile 442 '93 Chevy 2WD C1500 350 Silverado Extended Cab Shortbed '95 Chevy 4WD K2500 454 Silverado Extended Cab Long Bed |
| thats what I was looking for, thanks
| i tried to pull the codes on my truck with my scanner, because the check gage light keeps flickering on and off for the first few blocks of driving. the code reader will not pull any codes even when the light is on, the tech guy for the code scanner said it will only pull check engine codes. i am afraid you will have to go to a dealer to have it put on a machine.
| You guys are confusing the "Check Guages" light with the "Check Engine Light" two seperate and unrelated lights...
| ok Ill clear up my problem, its the check GAUGES light and I think I may have found the problem! it was the coolant I needed some more and it was close to overheating this morning but luckilly wal-mart was right there and I fixed that problem
| I don't. Coolant might be more than water but you don't want to run straight water, or you'll have a nightmare of rust built up in the coolant system.
| 4 oxygen sensor codes | lugnut | GMC Truck Forum | 1 | 05-02-2007 01:58 AM |
| GMC options and codes? | J-ROCK | GMC Truck Forum | 6 | 02-15-2007 05:02 PM |
| 1998 S-10 Engine Codes | 1935ford | Chevy Truck Forum | 4 | 02-06-2007 11:40 PM |
| GMC option codes | shorty27 | GMC Truck Forum | 5 | 07-13-2006 10:46 AM |
| rpo codes | vanhal | Chevy Truck Forum | 2 | 05-04-2006 03:16 PM |
