Old 03-27-2007, 08:17 PM   #1
riata_ag is on a distinguished road
4wd hubs won't engage
I have a 1990 3500 4X4 with an auto tranny. The transfer case works and the front driveshaft turns, but the front hubs won't engage.
Can someone give me some suggestions of what to do and where to look first.
Thanks,
riata
riata_ag is offline   Reply With Quote
Old 03-27-2007, 08:19 PM   #2
junior3382's Avatar
Bearings.... are they manual locking? If so, do they turn to lock? Does it wistle at all when you drive it, thinking its engaged? If so, i would definitely check the bearings on both ends.
Parts have been found, tools are collecting, tensions are rising, the weather is changing...look out.... the SAS is comming!
Old 03-27-2007, 08:41 PM   #3
Its a dually with the big steel dually wheels on the front.
The center of them is hollow with only an axle nut showing back in the hole in the wheel. So I assume they are auto locking, but I wasn't sure if they were like the mid-90's Ford hubs, or if they worked off of vacum or electric, etc..
Realizing that they are 17 years old maybe I need to buy new hubs?
Thanks in advance for your suggestions.
riata
Old 03-27-2007, 08:50 PM   #4
junior3382's Avatar
Okay, you need to determine for sure if they are auto or manual locking. and no, you may not need whole new hubs, depends on why they are not engageing. Once you determine wich hub you have, the diagnosis can continue....
Did you buy it used? I am assuming you did since it is rare people keep vehicles for that long, but I ask because when you bought it, did the 4x4 work? Did you check? usually a good item to check.
still sounds like a lube problem to me though... Depends on how long it has been since the system was used. Do you know how long it has been?
Old 03-27-2007, 09:01 PM   #5
I assume they are not MANUAL since there is not a a dial or switch to turn, right?
Yes, I did recently purchase the truck to use as a feed truck and I did try out the 4WD as far as the transfer case working, but I had to wait for rain so I could spin the tires a little in the mud to see if the front tires were spinning, and they weren't. I think it has been about 8-10 years since the 4wd was last used.
Old 03-27-2007, 09:10 PM   #6
junior3382's Avatar
Okay, you are right about the hubs. And with it being that long of not being used, either the mechanical actuator is rotted or yes, may need new hubs. So it doesn't grind at all? Or make any strange noise when you try to activate it? Usually the auto ones will continue to try, and end up either grinding, whistling or making a strange noise of some sort. Does the truck have a solid axle fron or an IFS?
Old 03-27-2007, 09:25 PM   #7
its not a solid front axle.
It has small CV axles connected from the diff. to the hubs.
Old 03-27-2007, 09:31 PM   #8
junior3382's Avatar
Okay, check those, if it hasn't been driven in that long, then that could be your problem. So I take it there are no noises, so check for tears and leaks of fluid in the boots. At least those are a little less expensive then whole new hubs. however, if they are broken or at least breaking, there would be a clicking when you turn wile driving..... but this is proof that just like men with sex, your truck needs the 4x4 engaged and used at least once a year, wether you need it or not....lol. Let us know.
Old 03-28-2007, 09:24 AM   #9
436'd skylark is just really nice436'd skylark is just really nice436'd skylark is just really nice436'd skylark is just really nice436'd skylark is just really nice
The front of your truck doesn't have hubs, The CV shafts is directly splined to the wheels. the engagement and disengagement is done in the differential. There is a thermal actuator that switches on when the lever is pulled via a switch in the transfer case. The actuator heats up and expands and pushes something in the front diff to engage. This system is notoriously slow and crappy. It normally takes 10 or 15 seconds to engage, which seems like a lifetime to wait, every time.
There a few things to check. First, you might not have waited long enough, like I said it takes along time.
There is a fuse for the actuator in the fuse box, labeled "4x4" it might be popped. If it is, replace it. Pull it in 4x4, and if it instantly pops again, the actuator is likely shot. its a dealer only item around 75-100 bucks. very easy to replace
The connector is under teh truck and could be corroded. If the fuse is good, un plug the connector while the truck is in 4x4 and make sure you have power at the connector.
more than likely the actuator is toast. common on those.
Joe
89 K2500 Chevy, Wee-Oh-five
285K miles, completly rebuilt
needs a motor, bad
152 ci, dana everything else
436'd skylark is online now   Reply With Quote
Old 03-28-2007, 02:00 PM   #10
Thanks alot
I finally realized today after thinking about it that those CV axles do turn all of the time.
I will check out that fuse and electrical switch tonight.
Locking Front Hubs Question 49162 Ford Truck Forum 4 12-26-2006 05:24 AM
Front Hubs on 2WD Jimmy S15 jktuck GMC Truck Forum 0 12-22-2006 02:37 PM
auto hubs colocat Ford Truck Forum 2 05-01-2006 05:47 PM
Auto Locking Hubs 74pilot GMC Truck Forum 1 11-20-2005 11:57 PM
Ohio man accused of helping minor engage in truck stop prostitution (Ohio News Network) trucknews Truck News (headlines) 0 06-11-2005 05:30 PM
