Old 03-30-2007, 09:43 AM   #11
03chevy's Avatar
if the head is the only thing wrong with the motor and 300k miles replace the head and keep on riding. unless you feel like havin more horses under the hood with that little truck and just fill like tricking it out and all
Old 03-30-2007, 03:00 PM   #12
Moderator
if money was not that much of an issue, i would look into a different engine. daddy was poor and always works on his stuff. with that many miles, you will end up working on something alot sooner if you went back with the original block. if i had the money, i would go with a newer, maybe not brand new, block and not worry about it for another good while because there is nothing worse than being on the side of the road dead.
Old 03-30-2007, 03:01 PM   #13
72'CaminoKid's Avatar
72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold72'CaminoKid is a splendid one to behold
probably best bet would be rebuild the entire engine you have now... will probably be cheapest route
99 suburban xlt
96 silverado
91 wrangler (my baby )
Old 04-03-2007, 09:00 PM   #14
junior3382's Avatar
i dunno about that, I have seen some engines sell rebuilt for like fifteen hundred dollars, and with a warranty, and sometimes to rebuild an existing may cost less in parts, will kill you in labor. Even doing it yourself, unles you have a complete machine show and can re-man the heads and re-press the seals, the cost just climbs. I would rather re-place and have peice of mind then rebuild and risk further issues. But that is just me.
Parts have been found, tools are collecting, tensions are rising, the weather is changing...look out.... the SAS is comming!
Old 04-04-2007, 06:20 AM   #15
Moderator
the engines that you are referring to are mainly the ones with DOHC. i have seen some sell for as much as 2 and 3 grand. being a chevy block like this one, i can go to a rebuild shop and get a newly rebuilt one for a 750 with the core.
Old 04-04-2007, 03:51 PM   #16
0425004x4's Avatar
0425004x4 is on a distinguished road
Advance adapters can sell you everything you need from a low mileage take out motor to new crate engines. The swap will be really simple as long as you have the non classic 99 body style. Everything you need is available new or at the wrecking yard. The book values on the 6s are misleading. The 6s bring thousands less here if the trucks are equipped the same. You are better off replacing the motor with what you want then replacing truck you know what you have as far as trans, steering, brakes etc..
0425004x4 is offline   Reply With Quote
2005 Yukon Denali engine swap to a Vortec 8100 ??? riskyvt GMC Truck Forum 5 07-13-2008 05:52 PM
87 Suburban engine Swap BuddyRo GMC Truck Forum 6 03-29-2007 08:12 PM
Lt1 Engine Swap SBHoney Chevy Truck Forum 4 01-29-2007 10:54 AM
Carb to TBI engine swap klink70 Chevy Truck Forum 5 02-17-2006 10:54 AM
Engine swap ? 72farmtruck Chevy Truck Forum 3 11-10-2005 09:57 PM
